09-16-2019 09:03 PM
I don't have any visibility application & TCP optimization monitor from vmanage.
How can I get the visibility with ISR platform?
09-17-2019 06:31 AM
Under SYSTEM
"tcp-optimization-enabled"
and under VPN 1
interface Ge0/2
You must do on both ends, - but be warned, it will break many apps, unless you create a very specific tcp-optimization policy per each app.
I had SAP failed on me.
09-17-2019 11:07 AM
For application visibility you'll one of these two:
policy
app-visibility
flow-visibility
Then go under the device template and in the additional templates select the local policy.
For the TCP Optimization please note that they're not yet commited to the IOS-XE SD-WAN image.
They're in the roadmap, but that's why you cannot see any details under those menus.
Please rate helpful posts.
