Choose one of the topics below for SD-WAN Resources to help you on your journey with SD-WAN
For production deployment issues, please contact the TAC!
We will not comment or assist with your TAC case in these forums.
116
Beginner
SD-WAN How to enable application monitor from vmanage & TCP optimization(ISR platform)
I don't have any visibility application & TCP optimization monitor from vmanage.
How can I get the visibility with ISR platform?
2 REPLIES 2
Beginner
Re: SD-WAN How to enable application monitor from vmanage & TCP optimization(ISR platform)
Under SYSTEM
"tcp-optimization-enabled"
and under VPN 1
interface Ge0/2
You must do on both ends, - but be warned, it will break many apps, unless you create a very specific tcp-optimization policy per each app.
I had SAP failed on me.
Beginner
For application visibility you'll one of these two:
  • From CLI make this addition
policy
app-visibility
flow-visibility
  • From the vManage you'll need to do the following
    • create a localized policy
    • In policy overview in localized policy configuration check this check boxes
      • Netflow
      • Application
Then go under the device template and in the additional templates select the local policy.
For the TCP Optimization please note that they're not yet commited to the IOS-XE SD-WAN image.
They're in the roadmap, but that's why you cannot see any details under those menus.
Please rate helpful posts.
Best Regards,
Please rate helpful posts,
Ruben Carvalho CCIE#57952
Content for Community-Ad
July's Community Spotlight Awards
