11-22-2018 07:23 AM - edited 03-08-2019 05:32 PM
Hi together,
I have a problem with the vManage VM. I have an ESXI with the vManage.
I did the following steps installing vManage:
But the Problem is, vManage is not available. I am on a jump host with no security features. It is with the Server in the same Net. Therefore, i think its not a problem with the firewall...
I can ping the Vm and it is possible to connect via ssh to the cli but connectiong via https is not possible. (Connection Failure)
The steps to configure are:
# config
(config)# vpn 512
(config)# ip route prefix/length next-hop-ip-address
(config-vpn-512)# interface eth0
(config-interface-eth0)# ip address ip-address
(config-interface-eth0)# no shutdown
(config-interface-eth0)# commit and-quit
Website link:
https://ip-address:8443/
Do you have any idea to fix the problem?
04-11-2019 06:46 AM
04-11-2019 12:12 PM
05-15-2019 12:41 PM
This has been fixed for me when assigned more then 8 GB RAM
04-04-2020 11:02 PM
I was able to fix the issue by formatting 100G drive.
First, I was only selecting 100G every time it boots and selects No when asked to format. The result was NMS Application server failed to run.
04-29-2021 10:11 PM
I changed the server and normalized.
