08-29-2019 09:56 AM
I'm building a lab and just want to have vManage/vBond/vSmart connected at this point.
I added vBond to Controllers list and applied a template to it. It sits with "Sync Pending - Device is offline" Status. But the devices are obviously communicating with each other. If feels like some kind of authentication is not passing.
- I already applied enterprise certificates, vManage cert status is "vBond Updated" and vBond cert status is "Installed"
- vManage vpn0(private IP) can reach vBond vpn0 (public IP)
- enterprise certificate org name matches vManage org name
vBond# show orchestrator local-properties
personality vbond
sp-organization-name orgname
system-ip 123.123.123.2
certificate-status Installed
root-ca-chain-status Installed
certificate-validity Valid
certificate-not-valid-before Aug 28 16:05:04 2019 GMT
certificate-not-valid-after Jan 09 16:05:04 2021 GMT
chassis-num/unique-id af028923-eea0-4984-a5b3-a717267c9e99
serial-num 084D6A4B4A3713E2041C87030F055D69057E81AC
number-active-wan-interfaces 1
protocol dtls
INSTANCE INDEX PORT VSMARTS VMANAGES STATE
0 0 12346 0 0 up
vBond# show control local-properties
personality vedge
dns-name #IP ADDRESS HERE#
site-id 200
domain-id 1
protocol dtls
tls-port 0
token Invalid
keygen-interval 1:00:00:00
retry-interval 0:00:00:18
no-activity-exp-interval 0:00:00:20
dns-cache-ttl 0:00:02:00
port-hopped FALSE
time-since-last-port-hop 0:00:00:00
embargo-check success
number-vbond-peers 0
number-active-wan-interfaces 0
vBond# sh run
system
host-name vBond
site-id 200
admin-tech-on-failure
no route-consistency-check
upgrade-confirm 60
vbond x.x.x.x local
aaa
auth-order local radius tacacs
usergroup basic
task system read write
task interface read write
usergroup netadmin
usergroup operator
task system read
task interface read
task policy read
task routing read
task security read
usergroup tenantadmin
user admin
password $6$L5aqWo5QuILubDZW$.DZc3TM3U9XJd.5R0
logging
disk
enable
omp
no shutdown
graceful-restart
advertise connected
advertise static
security
ipsec
authentication-type ah-sha1-hmac sha1-hmac
vpn 0
interface ge0/0
ip address x.x.x.x./28
ipv6 dhcp-client
no shutdown
ip route 0.0.0.0/0 x.x.x.x
vpn 512
interface eth0
ip address 10.161.180.51/24
no shutdown
ip route 10.161.50.0/24 10.161.180.1
If anyone has any ideas I'd highly appreciate your help.
Dan
08-30-2019 06:45 AM
vBond IP was incorrect in vManage running config. I updated it and vBond is up now. My fault, sorry for wasting your time.
Dan
08-30-2019 06:55 AM
No worries. Thanks for posting the solution.
