Choose one of the topics below for SD-WAN Resources to help you on your journey with SD-WAN
For production deployment issues, please contact the TAC!
We will not comment or assist with your TAC case in these forums.
482
Highlighted
Beginner
Viptela vEdge Cloud authentication problem
Hi guru! I need help in troubleshooting strange vEdgeCloud authentication problem: When I issue command request activate vedge-cloud the NMS showed the error for corresponded device "Certificate Installation Error". Howether if i repeat the command in CLI (use arrow up + Enter) the device successfuly registered. I lost in my guesses what could be wrong.
Everyone's tags (1)
1 ACCEPTED SOLUTION
Highlighted
Re: Viptela vEdge Cloud authentication problem
Check if the clocks are synced between the vEdge and the controllers.
Also check the certificate status on the vManage for the UUID if there is more detailed error there.
3 REPLIES 3
Highlighted
Highlighted
Beginner
Nothing interesting there. it shows the CSR in plain text
Highlighted
Beginner
Yes it sound like it was a root cause. Well in fact the root cause was the firewall block ntp sync request and in turn the clock were not synchronized.
