05-02-2019 04:53 AM
Please help us to clarify what type of network adapter supports the VRRP configuration in Cisco vEdge router, as we came across a document stating "VRRP for Cisco vEdge cloud is not supported on E1000 and VMXNET3 I/O types from 18.3 version onwards. [CSCvn53200/VIP-48217]", which is listed below Outstanding Issues > Forwarding part. Our ESXi version is 5.5 build 2, vEdge version 18.4.0 and the link we referred is https://sdwan-docs.cisco.com/Product_Documentation/Software_Features/Release_18.4/Release_Notes/Release_Notes_for_IOS_XE_SD-WAN_Release_16.10_and_SD-WAN_Release_18.4
It would be great if someone can help us in this regards.
Thanks in advance.
Akchaiah
05-06-2019 12:12 PM
We've hit the same issue. The answer was that is indeed not supported at all on the vedge-cloud starting with 18.3 until further notice, on any type of adapters. The official "workaround" is to use hardware vedges.
05-07-2019 04:22 AM
05-07-2019 08:45 PM
Hope you have upgraded the version. ? 18.4.1 software vedge works fine with VRRP. but you need to have E1000 interface. VMXNET3 interface will give an error "Virtual mac address cannot be created".
05-08-2019 02:07 AM
05-08-2019 03:04 AM
Hi ekhabaro,
I didnt realize that this is even a bug, when i started configuring VRRP , it was giving a message "Addition of virtual mac address not supported on this device on interface". But then i changed the adapter type from VMXNET3 to E1000 using Vmware powershell. Then the configuration was successfull.
I was able to ping even.
vEdge01# ping vpn 30 10.50.0.6
Ping in VPN 30
PING 10.50.0.6 (10.50.0.6) 56(84) bytes of data.
64 bytes from 10.50.0.6: icmp_seq=1 ttl=64 time=0.008 ms
64 bytes from 10.50.0.6: icmp_seq=2 ttl=64 time=0.013 ms
64 bytes from 10.50.0.6: icmp_seq=3 ttl=64 time=0.019 ms
But strangely, since you asked whether, i was able to ping, i tried from all of the nodes and it looks like you are absolutely right about it, i am not able to ping from all of the vEdge participating in VRRP. If its a known issue, i better wait for it be fixed.
Thanks for your reply.
05-08-2019 05:35 AM - edited 05-08-2019 10:38 AM
Thanks a ton Joe-Jose, I'm able to configure VRRP after changing the adapter type to E1000. Will wait for the official fix.
