Choose one of the topics below for SD-WAN Resources to help you on your journey with SD-WAN
For production deployment issues, please contact the TAC!
We will not comment or assist with your TAC case in these forums.
56
Beginner
vSmart image will not load in vContainer
I am attempting to stand up a multi-tenant configuration in my lab.  I have created the vContainer server with a 20G second drive, loaded the viptela-smart-18.3.7-genericx86-64_vhd.tar.gz image into the admin home directory.  When I issue the request container image install /home/admin/viptela-smart-18.3.7-genericx86-64_vhd.tar.gz command, it sits for some time and then says 'Failure'.  Looking at the vcontainer.log in /var/log, I'm seeing the error below.  What would be causing this or how to fix it?
Wed Aug 14 17:14:34 UTC 2019: Running image_install cli image /home/admin/viptela-smart-18.3.7-genericx86-64_vhd.tar.gz
mount: special device /var/lib/docker/tmpvip/container/rootfs.img does not exist
Everyone's tags (2)
Content for Community-Ad
July's Community Spotlight Awards
