How to reset System Password on SRW2024
dougstringham
I have very limited knowledge in the area of switches... but strong expertise with computers in general.
Our SRW2024 switches were configured several years back, and somewhere along the way someone set and lost the passwords.
How does one go about resetting the passwords?
Thanks!
regedit10
I try follow the step to reset default but it doesn't apply.
1) After connecting the serial cable to switch and system you’ll need to open a program such as Hyperterminal or Putty and enter the following settings:
  • Bits per second: 38400
  • Data bits: 8
  • Parity: None
  • Stop bits: 1
  • Flow Control: None
2) Connect power to the switch. After a couple of seconds you should see the prompt ‘Autoboot in 2 seconds – press RETURN or Esc. to abort and enter prom.’
PRESS Esc at this point – a second too soon, or a second too late and you’ll miss it. It’s a case of fastest reactions win!
3) The menu (shown below) will open – select option 3 to reset the password to null and then select option 5 to exit and continue the boot sequence
console_linksys_SRW2024_password
4) Once the logon prompt appears enter the username admin and leave the password field blank (either from the console or web interface)
5) Change the password to the desired setting
