Virtual Appliance Sizing - UDP Director & Flow Collector
TNSC2021
I am currently deploying Cisco Secure Network Analytics with Virtual Appliances.
Trying to figure out the hypervisor resources required.
Consulting the documentation here:
https://www.cisco.com/c/dam/en/us/td/docs/security/stealthwatch/system_installation_configuration/SW_7_3_2_VE_Appliance_Data_Store_Install_Guide_DV_1_0.pdf
The plan is to deploy a 3 node centralised data store.
Need to cater for 20K FPS.
According to documentation, UDP director with 2 vCPU / 4GB vRAM / 60GB storage will handle 10K FPS.
To me that means I need quantity 2 to scale to 20K FPS.
Is it possible to just increase the allocation of vCPU / vRAM / storage to cater for 20K FPS?
How does the UDP director scale? Is it linear? Or exponential. Some guidance would be great.
Also, the Flow Collectors when used with a centralised data store, do they still need the same level of hypervisor resources?
6 vCPU / 32GB vRAM / 200GB storage for 50K FPS.
Or can this be scaled down since a centralised data storage is being used?
0 Replies 0
