DMVPN: Dual Hub Dual Cloud VS Dual Hub Dual Cloud: Pros and Cons
604
meddane
Frequent Contributor
DMVPN Dual Hub Dual Cloud Pros and Cons
Pros
No single point of failure
Quick failover if routing protocols are tuned
Load balancing is easy
Traffic engineering is easy
Easy to work with multiple ISPs
Cons
Need 2 tunnels per spoke
Configuration is more complicated
DMVPN DMVPN Dual Hub Dual Cloud Pros and ConsPros and Cons
Pros
Quick failure if protocols are tuned
Easy to configure
Only 1 tunnel interface per router
Cons
Traffic engineering can be tricky depending on the desired goal
Create
Recognize Your Peers
Content for Community-Ad
