John Heintz
Updated!!
Posting this for anyone interested in using a Raspberry PI as a flow collector for Stealthwatch.  We created a very lightweight version of the Stealtwatch Cloud sensor.  It will create flows on any ethernet port, so you can attach LAN port to SPAN and/or forward NetFlow/IPFIX to it.  I would recommend keeping device counts under 100.
We now have an IMG file that works on Pi versions 3 or 4.  Thanks to Steven Marin who created it.
Cisco Employees get to keep their SWC account as long as it is being usedhttps://www.cisco.com/c/en/us/products/security/stealthwatch/stealthwatch-cloud-free-offer.html
Cheers - John
See attachment for directions on using pre-built Image
Package Install on existing PI (not a full image)
sudo apt-get install tcpdump
sudo apt-get update && sudo apt-get install -y libglib2.0-0 liblzo2-2 libltdl7 libpcap0.8 zlib1g
wget https://onstatic.s3.amazonaws.com/ona/master/ona-service_RaspbianJessie_armhf.deb
sudo dpkg -i ona-service_RaspbianJessie_armhf.deb
wget https://github.com/bbayles/netsa-pkg/releases/download/v0.1.18/netsa-pkg_raspbian.deb
sudo dpkg -i netsa-pkg_raspbian.deb
10 Comments
dcappell
It was easy to send NetFlow from my Meraki MX to the Pi running the sensor code!  Thanks for sharing! 11_14_47.jpg
ravega
Just tried this and it works like a charm! thank you Steven for making this image available. I just ran into a small issue with the priority of the interfaces. The raspberry will default to the Eth0 interface which in my case will be used to connect to a SPAN port so when I connect Eth0 it loses internet connectivity. This can be easily solved by modifying the interface metric parameter on this file:
 /etc/dhcpcd.conf
just add the following configuration and reboot
interface eth0 metric 300
interface wlan0 metric 200
Cheers
Randall Vega
Jefkelle
Are there any ports for Buster, Buster 64, and Ubuntu?
chyates
the commands in the dhcpcd.conf file need to be on separate lines to work correctly
interface eth0
metric 300
interface wlan0
metric 200
stmarin
If image link is broken use this as alternative:
Raspberry Pi Custom Buster Image (ONA)
dcappell
Just had to reinstall and setup my Raspberry Pi sensor - SSD card went bad with all the power hits from the weather last week - the new v3 directions worked well and the image link from stmarin that was posted also worked great - thanks!
crondero
I got this set up very quickly thanks to your help!
I had a few questions and Stealthwatch / SWA support helped with a few more pieces of information:
Details on how to configure and manage the SWC sensor via CLI can be found here:
https://ebooks.cisco.com/story/swc-sensor-install/page/1
In particular, if you have a dynamic IP and prefer to have the sensor tied to your account directly you can edit (requires sudo):
/opt/obsrvbl-ona/config.local
And add these two lines:
OBSRVBL_HOST="https://sensor.obsrvbl.obsrvbl.com"
OBSRVBL_SERVICE_KEY="<key>"
The <key> is found in your SWC / SWA dashboard under Settings > Sensors.
After saving the file, restart the service with:
sudo service obsrvbl-ona restart
crondero
2023 Update - many of the files listed here are no longer available.  I have the .deb files and an image available internally to Cisco at the box link below.
The .deb files should be good, as they were still sitting in the home directory from when they were downloaded when I originally followed the install instructions in 2020.  If you create a new Pi from scratch and leverage the deb files, it will be important to tweak the /etc/dhcpcd.conf and optionally the /opt/obsrvbl-ona/config.local files to get the sensor working correctly.
I attempted to create the image file from my running sensor.  It may not work as expected.  Please test it and let me know your results.  The username and password are the default pi/raspberry.
https://cisco.box.com/s/j6f918qgqa26kaabbnqbygbod7893zkl
snyce
Ona service packages have been removed from direct S3 access and have been moved behind CloudFront for better visibility.
Here are the updated commands to install:
The only change being the location of the RaspbianJessie_armhf.deb.
wget https://assets-production.obsrvbl.com/ona-packages/obsrvbl-ona/v5.1.1/ona-service_RaspbianJessie_armhf.deb
oldskool76
Is it possible for anyone to post an updated built image? Having issues.
