Mizanul Islam
Hi All,
Unable to Access Inside PC from outside network. Here is the error given below. I have configure access-list outside any any
also i have configured icmp any any but i couldn't communicate. I have check all access-list and access-group. everything ok.
%ASA-3-106014: Deny inbound icmp src interface_name: IP_address dst
interface_name: IP_address (type dec, code dec)
PID: ASA5515
Software Version 9.0(4)
-01# sho run
: Saved
ASA Version 9.0(4)
enable password fNfvz0nxWqnzuVsW encrypted
xlate per-session deny tcp any4 any4
xlate per-session deny tcp any4 any6
xlate per-session deny tcp any6 any4
xlate per-session deny tcp any6 any6
xlate per-session deny udp any4 any4 eq domain
xlate per-session deny udp any4 any6 eq domain
xlate per-session deny udp any6 any4 eq domain
xlate per-session deny udp any6 any6 eq domain
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface GigabitEthernet0/0
description *** Connected to CORE-SW-01 ***
channel-group 11 mode active
no nameif
no security-level
no ip address
interface GigabitEthernet0/1
no nameif
no security-level
no ip address
interface GigabitEthernet0/2
no nameif
security-level 0
no ip address
interface GigabitEthernet0/2.32
vlan 32
nameif inside
security-level 100
ip address 10.98.32.3 255.255.255.0
interface GigabitEthernet0/3
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/4
description LAN/STATE Failover Interface
interface GigabitEthernet0/5
shutdown
no nameif
no security-level
no ip address
interface Management0/0
management-only
nameif managment
security-level 0
ip address 10.10.111.1 255.255.255.0
interface Port-channel11
description *** Connected to CORE-SW ***
nameif outside
security-level 100
ip address 10.98.8.90 255.255.255.248 standby 10.98.8.91
boot system disk0:/asa904-smp-k8.bin
ftp mode passive
dns server-group DefaultDNS
domain-name midlandbankbd.net
object network IT-Network
subnet 10.108.1.0 255.255.255.0
access-list test extended permit icmp any 10.98.32.0 255.255.255.0
access-list IPS_ACL extended permit ip any4 any4
access-list test1 extended permit ip any any
pager lines 24
logging enable
logging buffered informational
logging trap informational
logging asdm informational
mtu inside 1500
mtu managment 1500
mtu outside 1500
failover
failover lan unit primary
failover lan interface failover GigabitEthernet0/4
failover polltime unit msec 200 holdtime msec 800
failover polltime interface msec 500 holdtime 5
failover key *****
failover replication http
failover link failover GigabitEthernet0/4
failover interface ip failover 10.98.60.1 255.255.255.252 standby 10.98.60.2
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
access-group test1 in interface inside
access-group test in interface outside
route outside 10.108.1.0 255.255.255.0 10.98.8.89 1
route outside 10.108.200.247 255.255.255.255 10.98.8.89 1
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
aaa authentication ssh console LOCAL
http server enable
http server idle-timeout 5
http server session-timeout 5
http 0.0.0.0 0.0.0.0 outside
http 0.0.0.0 0.0.0.0 managment
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
crypto ipsec security-association pmtu-aging infinite
crypto ca trustpool policy
telnet timeout 5
ssh 0.0.0.0 0.0.0.0 managment
ssh 0.0.0.0 0.0.0.0 outside
ssh timeout 5
console timeout 0
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
username mdbladmin password xmMhtANupK0CJ7AP encrypted privilege 15
class-map IPS_CL_MAP
match access-list IPS_ACL
class-map inspection_default
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map CMP_DMZ_MAIL_SMTP
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect ip-options
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
  inspect http
  inspect dns preset_dns_map dynamic-filter-snoop
  inspect icmp
class IPS_CL_MAP
  ips inline fail-close
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
call-home
profile CiscoTAC-1
  no active
  destination address http
https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email
callhome@cisco.com
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly 3
  subscribe-to-alert-group configuration periodic monthly 3
  subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:e540d639228d4fa4b3e9c2273432be88
: end
Jouni Forss
You should post questions in the Discussions section. This section is meant for user created documentation.
- Jouni
