> Create a new VSA for Bluecoat with vendor ID 2334. Under "system configuration -> Dictionaries -> Protocols -> Radius -> Radius VSA"
> Create a sub-attribute "Packeteer-AVPair" for Bluecoat with Vendor attribute ID = 26 and Type "STRING"
> Create a Authorization Profile "Permit-access-test-RW" under Policy Elements and defined Radius attributes "access=touch"
> Assigned this authorization profile "permit-accss-test-RW" under Access Policy network access rule.
> Repeat the above procedure with different subattribute "Packeteer-PC-AVPair" and an authorization profile
"permit-access-test-RO" define "access=look".
Jatin
