Jatin Katyal
> Create a new VSA for Bluecoat with vendor ID 2334.  Under "system configuration -> Dictionaries -> Protocols -> Radius -> Radius VSA"
> Create a sub-attribute "Packeteer-AVPair" for Bluecoat with Vendor attribute ID = 26 and Type "STRING"
> Create a Authorization Profile "Permit-access-test-RW" under Policy Elements and defined Radius attributes "access=touch"
> Assigned this authorization profile "permit-accss-test-RW" under Access Policy network access rule.
> Repeat the above procedure with different subattribute "Packeteer-PC-AVPair" and  an authorization profile
"permit-access-test-RO"  define "access=look".
Jatin
arrows630
Community Member
I tried to authentication for Bluecoat device as your setting using ACS5.1. However, I could not be success login to the Bluecoat device. ACS log seems to be success but Bluecoat log is "Access Denied". Which part should we confirm? I really appreciate your support.
