09-16-2020 03:40 PM - edited 09-16-2020 04:25 PM
What is SecureX?
All AMP for Endpoints subscriptions include Cisco SecureX, which is built-in. SecureX is a cloud-native platform that turns your infrastructure into a fully integrated ecosystem, by aggregating capabilities across the Cisco Security portfolio as well as 3rd party tools. It’s designed to simplify your security environment, improve visibility and context, and maximize your team’s efficiency.
What can I do with SecureX?
How do I connect to SecureX?
Click here for a YouTube video with instructions, or follow the step-by-step instructions below.
What’s an example of SecureX in action?
Great information on AMP for Endpoints. Plus very helpful links within this post.
Thank you for sharing!
Gus
In Umbrella we can thankfully turn OFF the SecureX bar -- it takes up WAY too much space on the screen in the current iteration. Why is it so big when it's not even being used? Is it just to get attention?
How do we turn it off or hide the SecureX bar in AMP4EP so it's not taking up the entire bottom of the screen? Unfortunately, clicking "X" just makes it bigger -- it behaves like adware in this respect: it won't go away.
In full-screen Device Trajectory, the SecureX bar makes it hard to work by significantly reducing the amount of screen available. In that view, we need as much of the screen as possible and the SecureX bar does not help.
Hope something can be done to make this better soon. Right now I can't stand SecureX for this reason. Thanks!
Hi @md11, we do want to increase awareness of the SecureX feature, but we definitely don't want it to be intrusive. Thanks for the feedback.
