Introduction
AnyConnect, as you all know, has been a well-known SSL VPN Client (both  for ASA and IOS headends), but not anymore, thanks to IKEv2. Recent  advancements in IKEv2 technology both in ASA and IOS, have made  AnyConnect 'THE' IKEv2 Client. However, the ikev2 version of the AC client was designed to incorporate the existing advanced features of the Anyconnect SSL client, like web deployment or automatic profile updates and so forth. Because of this, the ikev2 tunnel isn't a pure IPSEC tunnel, instead it requires SSL to enable all these features, otherwise known as "client services".  In this document we will see how to configure an ASA and an AnyConnect client, which eliminates the requirement for client services and ssl completely.
AnyConnect IKEv2 with ASA as headend
Requirements
  • ASA 5500 running 8.4.1 or above
  • AnyConnect License on ASA - Either AnyConnect Essentials or AnyConnect Premium Peers (Default: 2 AnyConnect Premium Peers)
  • AnyConnect 3.x
Configuration Steps
For Reference:
Connecting AnyConnect with ASA as Headend and SSL as the primary protocol
Overview
Step 1: Get a certificate (I am using Self-Signed-Certificate) or Get a third party certificate
Step 2: Load AnyConnect SMC Package on the ASA:
Step 3: Enable WebVPN on an interface and Allow AnyConnect
Step 4: Create a Group-Policy
Step 5: Configure the Connection Profile aka Tunnel-Group
Step 6: AnyConnect XML Profile Configuration:
Step 7: Add IKEv2 policies and Enable it on the desired Interface:
Step 8: Add IPSec Config and Enable it on the desired Interface:
Step 9: Users (In my case: Local Database)
Step 10: Configure AnyCOnnect Profile
Let us start with configuring the ASA from scratch. I will focus on CLI only:
Configuration
! RSA Keys
crypto key generate rsa general-keys label ASA-SSC modulus 1024
! Self-Signed Certificate trustpoint
crypto ca trustpoint ASA-SSC
     enrollment self
     fqdn bsns-asa5585-40-2.cisco.com
     subject-name cn=bsns-asa5585-40-2.cisco.com
     keypair ASA-SSC
     crl configure
crypto ca enroll ASA-SSC noconfirm
ssl trust-point ASA-SSC
! show crypto key mypubkey rsa
! show crypto ca trustpoint
! show crypto ca certificate
! show run all ssl
copy ftp://praveen:******@10.1.1.1/anyconnect-win-3.0.5080-k9.pkg flash
! Global Webvpn Config
webvpn
     enable outside
     anyconnect image disk0:/anyconnect-win-3.0.5080-k9.pkg 1
     anyconnect enable
     tunnel-group-list enable
! about the profile, check the "Profile" Section below.
! Split-Tunnel Access-list
access-list split standard permit host 10.1.1.1
! Group-Policy
group-policy IKEV2 internal
group-policy IKEV2 attributes
     wins-server none
     dns-server value 10.1.1.1
     vpn-tunnel-protocol ikev2
     split-tunnel-policy tunnelspecified
     split-tunnel-network-list value split
     default-domain value cisco.com
! VPN Client Pool
ip local pool VPN_POOL 10.2.2.1-10.2.2.50 mask 255.255.255.0
! show run tunnel-group AnyConnect
tunnel-group AnyConnect type remote-access
tunnel-group AnyConnect general-attributes
     address-pool VPN_POOL
     default-group-policy IKEV2
tunnel-group AnyConnect webvpn-attributes
     group-alias AnyConnect enable
     group-url https://bsns-asa5585-40-2.cisco.com/AnyConnect enable
! Make sure the group-url is: https://<fqdn/ip-address>/<Tunnel-Group-Name> and
! make sure it is consistent with the way the Server-Entry in the profile is defined (as below)
! show run crypto ikev2
crypto ikev2 policy 10
     encryption aes-192
     integrity sha
     group 2
     prf sha
     lifetime seconds 86400
crypto ikev2 policy 20
     encryption aee
     integrity sh
     group 2
     prf sha
crypto ikev2 enable outside
crypto ikev2 remote-access trustpoint ASA-SSC
!  Note: Due to the Bug: CSCty43072, if you are using one of the affected HostScan Images:
! use the same Trustpoint for IKEv2 and SSL as i have done  above
! Bug Link : http://goo.gl/Rkp3n
! show run crypto dynamic-map
crypto dynamic-map DynMap 1000 set pfs group1
crypto dynamic-map DynMap 1000 set ikev2 ipsec-proposal AES256 AES192 AES 3DES DES
! show run crypto map
crypto map outside_map 1000 ipsec-isakmp dynamic DynMap
crypto map outside_map interface outside
! show run username
username pshanubh password ******
username pshanubh attributes
     vpn-group-policy IKEV2
Profile
! Refer to the attached profile (anyconnect.xml) for template. It is reusable after editing the HostName,HostAddress and UserGroup
! Load the attached xml to:
C:\ProgramData\Cisco\Cisco AnyConnect Secure Mobility Client\Profile
(Or %PROGRAMDATA%\Cisco\Cisco AnyConnect Secure Mobility Client\Profile)
<ServerList>
          <HostEntry>
                <HostName>ASA-5585</HostName>
                <HostAddress>bsns-asa5585-40-2.cisco.com</HostAddress>
                <UserGroup>AnyConnect</UserGroup>
          <PrimaryProtocol>IPsec</PrimaryProtocol>
          </HostEntry>
    </ServerList>
! Here the UserGroup must be identical to the tunnel-group with which this profile is attached.
Important Note: Notice how the Profile is loaded only on the client machines, and not on the ASA. Refer to the upcoming Client-Services and Profile update section in this artical.
For More info:
https://supportforums.cisco.com/docs/DOC-23465
Verification
Now  that the profile (attached to this doc) exists on the PC, which dictates the client to  initiate an IPSec Session and the only way the AnyConnect client knows  how to perform IP-Security is using IKEv2, you will see the following on  the ASA:
Notice how it says IKEv2 IPSecOverNatT:
#  sh vpn-sess anyconnect
Session Type: AnyConnect
Username     : pshanubh               Index        : 9499
Assigned IP  : 2.2.2.1                Public IP    : 144.254.7.183
Protocol     : IKEv2 IPsecOverNatT AnyConnect-Parent
License      : AnyConnect Premium
Encryption   : AES256                 Hashing      : none SHA1
Bytes Tx     : 0                      Bytes Rx     : 1325
Group Policy : IKEV2                  Tunnel Group : AnyConnect
Login Time   : 07:20:33 UTC Fri Mar 23 2012
Duration     : 0h:00m:03s
Inactivity   : 0h:00m:00s
NAC Result   : Unknown
VLAN Mapping : N/A                    VLAN         : none
If you want to see more detailed output,
show vpn-sessiondb detail anyconnect
and the IKEv2 Security Association:
# show crypto ikev2 sa
IKEv2 SAs:
Session-id:14, Status:UP-ACTIVE, IKE count:1, CHILD count:1
Tunnel-id                 Local                Remote     Status         Role
994834887     10.48.67.233/4500   144.254.7.183/55624      READY    RESPONDER
      Encr: AES-CBC, keysize: 256, Hash: SHA96, DH Grp:2, Auth sign: RSA, Auth verify: EAP
      Life/Active Time: 86400/65 sec
Child sa: local selector  0.0.0.0/0 - 255.255.255.255/65535
          remote selector 2.2.2.1/0 - 2.2.2.1/65535
          ESP spi in/out: 0x7f8cf6fb/0x4b1ce95b
show crypto ikev2 sa detail
KiloBravo
Can someone confirm whether this it is mandatory to import the client profile to the local machine or not? I've been through the Cisco Press VPN book and it doesn't mention this step as being neccesary. However it wasn't working until i did this :S.
Would be grateful for any information on this.
ROBERTO GIANA
Level 4
Level 4
Are there plans to support the Windows 7 native client with IKEv2 and the ASA?
Roberto,
I am not sure if you have heard, but ASA 9.3(2) now supports Windows 7 Built-in IKEv2 client:
http://goo.gl/UZllWZ
Feature name:
Interoperability with standards-based, third-party, IKEv2 remote access clients
Nikhil Thakur
Hi kalebaks86,
It is mandatory to import the AnyConnect client profile on the client machine when you've client-services disabled for IKEv2 RAVPN connection to tell the client to initiate the connection using IPSec/IKEv2. This should be done after you've selected the Primary protocol to IPSec as the default is set to SSL.
As the client-services are disabled (no SSL connection but pure IKEv2 ) in the above scenario, if you deploy the AnyConnect profile on the ASA it won't be pushed to the client as it is only done over an SSL connection and not IKEv2 connection.
Hope that makes sense.
