ASA 5510: Allow Pings and ssh 'putty' connection to directly connected 2800 router
155
Hi All
I have an ASA 5510 with a DMZ interface that has a Cisco 2800 router directly connected to it.  I am having two issues:
1. I want to use WhatsUpGold on the Inside Lan to ping the router to monitor up status(at least the e0 int. directly connected to the ASA)
2. I want to connect to the router from the inside LAN using putty on port 22  (I believe I have configured the router properly to handle ssh connections on vty)  *Right now I get a Putty fatal Error:Network error: Connection refused
The issue is, on the ASA we have an ACL bound to the inside interface with a Deny IP any any statement at the end so it is adding a layer of difficulty.
Do I need an ACE to the inside ACL allowing access from Inside to DMZ interface eq ssh?  Same with ICMP Pings?
Content for Community-Ad
