please, i have a doubt about that certificate with openssl.
I could see on my old CAS on "X509 Certificate" tab that appears "ROOT CA Certificate" together with CCA Server certificate and private key but after I've generated a certificate with openssl my new CAS show me just CCA Server certificate and private key.
Why does root ca not appear?
thanks
for me SSL certificate is a litlle confuse, if you have any links to understand about it.
Because the identity certificate (certificate for the device) is the root certificate itself! It's a true self-signed certificate, and hence doesn't list itself as a root.
today i am trying to create a certificate from our microsoft server 2003 but without success!! do you know any material or guide that can I use to replace this certificate to microsoft certificate using NAC?
I was trying to export my certificate with my Private key and our server we try to use the webserver type but the 2003 server returns on *.cer file.
thanks a lot
