Hello @balaji.bandi @Rob Ingram I am planning to update AnyConnect Packages on ASA and have a few questions. Do I need to reboot the firewall to make the new package in effect? Also, will the clients update when ...
view more
Information on securing CISCO switchports.
I saw that it was possible to set more than one additional MAC address for a port, and if another MAC address connects, the packets are blocked.
Unfortunately I have a lot of PCs and servers, which becomes too lo...
view more
Guest Wifi ISEAfternoon all, I've been tasked to set up Guest WIFI. The bit I'm struggling with is the very last stage, In summary I'm using Self Register Portal. This Portal allows users to register for WIFI once it is approved and...
view more
Hello Community,I have to configure two IPSec tunnels on a cisco 4221 router, each tunnel should be established with a different router but the two tunnels should work in active/standby mode, how can I do this please?Topology is as below.  ...
view more
