Configuring DMVPN with ZBF (Hub and Spoke Topology)
17509
Objective:
To configure ZBF on both  a DMVPN  hub and a DMVPN spoke router.
Problem Description:
DMVPN(hub and spoke deployment) is a hub-and-spoke deployment model in which the primary enterprise resources are located in a large central site, with a number of smaller sites or branch offices connected directly to the central site over a VPN.
Zone Based Firewall is an advanced configuration model for the Cisco IOS Firewall feature set. It offers intuitive policies for multiple-interface routers, increased granularity of firewall policy application, and a default deny-all policy that prohibits traffic between firewall security zones until an explicit policy is applied to allow desirable traffic.
Often in case of small remote sites the DMVPN router serves not only as the GRE and Crypto aggregation router but also as the network edge device. In such cases, users often prefer to add an extra layer of security by enabling Zone Based Firewall feature set on the router. Network location of the crypto headend in relation to the headend firewall(s) impacts both the accessibility and performance of both systems. The network manager must ensure that all firewalls are properly configured to allow the tunnel traffic bi-directionally. The crypto headend must be accessible to the branch router because all crypto sessions are initiated by the branch router.
Prerequisites:
  1. DMVPN Design guide
  2. Basic DMVPN configuration guide
  3. ZBF Design and Application guide
Please note, only single tiered headened architecture is discussed in this document. In case of double tiered architecture, ZBF needs to be configured to allow GRE traffic on one router and IPSEC traffic on the other.
Scenario:
Solution:
One of the biggest differences between CBAC and ZBF is in the manner in which the firewall policies are applied.  In CBAC the inspection policies are defined per interface, however to improve granularity and flexibility in the firewall configuration, ZBF was modelled based on zones. Each interface is made part of a zone, and the inspection policies are applied between two zones. Usually the private networks are part of the in-zone, and the poblic networks are part of the out-zone. All traffic destined to any ip address on the router itself is part of the "self" zone. By default traffic from any zone to the self zone is permitted, however if there is a specifc out-self zone then special care needs to be taken to permit those kinds of traffic that will be destined to the router itself. Depending on the crypto and DMVPN headend or branch placements, the following protocols and ports are required to be allowed:
UDP Port 500—ISAKMP as source and destination
UDP Port 4500—NAT-T as a destination
IP Protocol 50—ESP
IP Protocol 51—AH (if AH is implemented)
IP Protocol 47—GRE
Routing protocol
Please keep in mind that the above considerations need to be made in additition to the configuration reqiured to allow normal traffic as desired.
There are various ways that routers can be configured. I have identified 4 such use cases base on what zone each interface is mapped to:
Use of 2 zones
interface
  zone
insideinternal
outsideexternal
tunnel
external*
*it is not recommended to configure the tunnel interface in the same zone as the inside interface, because in this case, the DMVPN traffic does not require any kind of zone pair configuration at all to allow the traffic to pass through, thus making the FW completely redundant as far as the DMVPN traffic is concerned.
Use of 3 zones
interface   zone
insideinternal
outsideexternal
tunnel
dmvpn
For both the above use cases you can refer to the document Using VPN with Zone-Based-Firewall for the configuration guide.
Use of self zone
In this particular use case the interfaces can be configured using either 3 or 2 zone as described above, however an additional self zone is also applied in the zone pair configuration to provide added protection against traffic sent to the router.
Configuration:
The following configuration example is for the case where:
1. the hub is configured with 2 zones along with a self zone
2. the spoke is configured with 3 zones along with a self zone
Configuration on Hub:
crypto isakmp policy 1
     encr 3des
     hash md5
     authentication pre-share
     group 2
crypto isakmp key cisco123 address 0.0.0.0 0.0.0.0
crypto ipsec transform-set dmvpn-trans esp-3des esp-md5-hmac
     mode transport
crypto ipsec profile dmvpn-pro
     set transform-set dmvpn-trans
class-map type inspect match-any self-out-class
     match protocol icmp
class-map type inspect match-any self-out-dmvpn-class
                    match access-group name test
                    match protocol isakmp
class-map type inspect match-any int-ext-class
     match protocol telnet
     match protocol ssh
     match protocol icmp
policy-map type inspect int-ext-policy
     class type inspect int-ext-class
          inspect
     class class-default
          drop
policy-map type inspect self-out-policy
     class type inspect self-out-dmvpn-class
       pass
     class type inspect self-out-class
       inspect
     class class-default
       drop
zone security internal
zone security external
zone-pair security int-ext source internal destination external
     service-policy type inspect int-ext-policy
zone-pair security ext-int source external destination internal
zone-pair security self-ext source self destination external
     service-policy type inspect self-out-policy
zone-pair security ext-self source external destination self
interface Tunnel1
     ip address 172.16.1.1 255.255.255.0
     no ip redirects
     ip mtu 1400
     ip nhrp authentication cisco123
     ip nhrp map multicast dynamic
     ip nhrp network-id 1
     ip nhrp holdtime 600
     zone-member security external
     no ip split-horizon eigrp 1
     tunnel source Ethernet0/1
     tunnel mode gre multipoint
     tunnel key 10000
     tunnel protection ipsec profile dmvpn-pro
interface Ethernet0/0
     zone-member security internal
interface Ethernet0/1
     ip address 1.1.1.1 255.255.255.0
router eigrp 1
     network 192.168.1.0 0.0.0.255
     network 172.16.1.0 0.0.0.255
     auto-summary
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 1.1.1.2
ip access-list extended test
     permit gre any any
     permit esp any any
     permit eigrp any any
Configuration on Spoke:
     encr 3des
     hash md5
     group 2
     mode transport
     match protocol ssh
     match protocol icmp
class-map type inspect match-any self-ext-class
     match protocol icmp
class-map type inspect match-any self-ext-dmvpn-class
     match access-group name test-dmvpn
class-map type inspect match-any dmvpn-ext-class
     match protocol icmp
policy-map type inspect dmvpn-ext-policy
     class type inspect dmvpn-ext-class
       inspect
     class class-default
       drop
       inspect
     class class-default
       drop
policy-map type inspect self-ext-policy
     class type inspect self-ext-class
       inspect
     class type inspect self-ext-dmvpn-class
       pass
     class class-default
       drop
zone security dmvpn
zone-pair security int-dmvpn source internal destination dmvpn
zone-pair security dmvpn-int source dmvpn destination internal
     service-policy type inspect self-ext-policy
interface Tunnel1
     ip address 172.16.1.2 255.255.255.0
     ip mtu 1400
     ip nhrp map multicast 1.1.1.1
     ip nhrp map 172.16.1.1 1.1.1.1
     ip nhrp nhs 172.16.1.1
     zone-member security dmvpn
     tunnel destination 1.1.1.1
     tunnel key 10000
     ip address 192.168.2.1 255.255.255.0
     ip address 2.2.2.1 255.255.255.0
     zone-member security external!
ip access-list extended test-dmvpn
     permit esp any any
     permit gre any any
Known Caveats:
  1. CSCtn65512 - ZBF drops DMVPN traffic post IPSec decryption when using shared TP
  2. CSCta00183 - ZBF: Adding ins for esp from out to self zone may break DMVPN and EIGRP
Suggested Reading:
  1. DMVPN with CBAC configuration
  2. Using VPN with Zone-Based Firewall
  3. Anyconnect on IOS with ZBF
Contributor
thank you for the posting
that is what i was looking for
i addition, my requirements also need NAT and
a means to ensure all SPOKE traffic only goes to the HUB
I am required to have the HUB acts as the inet gateway
even though most of my spokes will connect over the inet, their traffic needs to be "tunneled" to the HUB
some SPOKE sites are on the corporate network, they will be treated the same.
This ensures that we can moinitor and control inet traffic without having to replicate the strong filtering and monitoring at all SPOKE sites
any tips or advice? for the later two addional requirements?
Beginner
pretty nice guide. I have got few questions though. We are using separate ACLs for self-out and out-self zone pairs. in out_to_self ACL we have allowed gre any any but not in self_to_out ACL and the tunnel works fine. Also we did not permit eigrp any any (in both ACLs) and the neighbours come up with no problem. Could you provide some insight into this? I
Martin, I would need to take a look at the configuraiton that you have could you post it here?
Walter, to control the traffic from the spokes so that they only go to the hub before they go anywhere else, you just need to control the routing. For example if you are using EIGRP then removing then enabling next-hop-self instead of disabling it should fix this issue for you. As far as NAT is concerned, just treat the tunnel interface like any other interface for natting, it should work.
Beginner
The physical interface is in outside, while the Tunnel interfaces are in zone "DMVPN". There is no eigrp protocol in either of the ACLs and GRE is allowed only in OUT->Self. I have changed the ACLs so they are mirrored. The EIGRP neighbour is up over 5 days now on both Hub and Spoke, the traffic flows fine, I can telnet and ping the destinations I need.
Beginner
amazing Atri !!! thank you !!!
Beginner
Thanks -- out of the 4 examples I found on the internet, this was the only one that actually worked. Seems the Pass is a requirement for ISAKMP, thus needing to create the zone-pair in opposite direction as well.
