dohurd
Allows Sourcefire to pass event details to F5's BigIP.  Big IP can insert an iRule to block or quarantine a device.
mabernar
This looks really cool, do you have any info on how to configure the remediation on the Firepower Management Center side of this?
Mark
mabernar
OK, so I think that you have to create a file with the pl script and the template like so:
tar cvzf f5.tar.gz f5remR1.pl module.template
Here are the guidelines for importing a remediation module:
https://www.cisco.com/c/en/us/td/docs/security/firesight/540/api/remediation/FireSIGHT-System-Remediation-API-Guide/WritingRemedClients.html#98540
Thanks Ben and Doug
