Kureli Sankar
Documentation
This configuration example is meant to be interpreted with the aid of the documentation from the configuration guide attached to this document.
IOS-XE guide: http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/sec_data_utd/configuration/xe-3s/sec-data-utd-xe-3s-book.html#concept_0AC4C1AE8D714F1C9533FD3B383EC8AF
UCS-E configuration guide: http://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/e/2-0/gs/guide/b_2_0_Getting_Started_Guide.html
Firepower Virtual Appliance and Defense Center Data Sheet: https://na8.salesforce.com/sfc/p/#80000000dRH9KXPLJqkSwWBoW3e_vtLbnXOyiNg=
Firepower 3D System Virtual Installation Guide 5.3: http://www.cisco.com/c/en/us/support/security/ngips-virtual-appliance/tsd-products-support-series-home.html
FireSIGHT or Defense Center configuration guide: http://www.cisco.com/c/en/us/support/security/defense-center-virtual-appliance/tsd-products-support-series-home.html
UCS-E Troubleshooting guide: http://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/e/ts/guide/e_series_ts.html
Prerequisite and code download links
ISR must run XE image 3.14 or above. Download here: http://software.cisco.com/download/release.html?mdfid=284389362&flowid=71903&softwareid=282046477&release=3.12.2S&relind=AVAILABLE&rellifecycle=ED&reltype=latest
Firepower virtual sensor image download here: https://software.cisco.com/download/release.html?mdfid=286259690&softwareid=286271056&release=5.3.0.8&relind=AVAILABLE&rellifecycle=&reltype=latest
FireSIGHT Management Center image download link: https://software.cisco.com/download/release.html?mdfid=286259687&softwareid=286271056&release=5.4.1.6&relind=AVAILABLE&rellifecycle=&reltype=latest
ESXi 5.0 or above. You can download VMWare customized image for Cisco here:
https://my.vmware.com/web/vmware/details?downloadGroup=CISCO-ESXI-5.1.0-GA-25SEP2012&productId=284
UCS-E140D and UCS-E160 Images: http://software.cisco.com/download/release.html?mdfid=284479266&softwareid=284480160&release=2.1.0&flowid=34485
UCS-E140S Images: http://software.cisco.com/download/release.html?mdfid=284479227&softwareid=284480160&release=2.1.0&flowid=34482
UCS-E120S Images: http://software.cisco.com/download/release.html?mdfid=286231777&flowid=50083&softwareid=284480160&release=2.2.2&relind=AVAILABLE&rellifecycle=&reltype=latest
BDI Doc in IOS-XE: http://www.cisco.com/c/en/us/td/docs/routers/asr1000/configuration/guide/chassis/asrswcfg/bdi.html
Goal
Is to implement Firepower on the UCS-E blade on ISR 4K or G2 in IPS mode using the Front Panel Port on the UCS-E blade
Requirement
Firepower sensor VM requirement is 4X4X40 (4 GB RAM, 4 vCPUs and 40 GB drive space). ESXi takes up 11 GB of space. So clearly a 50 GB drive is not sufficient.
Limitations
  • Restrictions for Bridge Domain Interfaces
    • Only 4096 bridge domain interfaces are supported per system.
    • Bridge domain interfaces do not support the following features:
      • Bidirectional Forwarding Detection (BFD) protocol
      • Netflow
      • QOS
      • Network-Based Application Recognition (NBAR) or Advanced Video Coding (AVC)
      • ZBF Refer: CSCui86271
      • For a BDI, the maximum transmission unit (MTU) size can be configured between 1500 and 9216 bytes.
      • Cryptographic VPNs are not supported in combination with BDI.
      • MPLS is not supported on bridge domain interfaces.
      • PPP over Ethernet (PPPoE)
      • NAT
Supported ISR and UCS-E Model
Supported ISRG2 and UCS-E Blades:
ISR Platform
Cisco UCS EN120E
Cisco UCS EN140N
Cisco UCS EN120S and E140S
Cisco UCS E140D and E160D-M2
Cisco UCS E160D-M1 and E180D
1921
No
No
No
No
1941
No
No
No
No
2901
No
No
No
No
2911
No
No
No
2921
No
No
2951
No
No
3925
No
No
3925E
No
3945E
No
Supported ISR4K and UCS-E Blades:
ISR Platform
Cisco UCS EN120E
Cisco UCS EN140N
4321
No
No
No
No
4331
No
2*
No
No
4351
No
3*
No
No
No
No
4451
No
3*
EN140N Module should have sufficient disk drive available to install Firepower Sensor VM.  We have tested with 100 GB drive.
Topology
Simple topology
Detailed topology
How Firepower Works
  1. LAN to WAN traffic that needs to be inspected arrive on the front panel port of the UCS-E blade. Allowed packet upon Firepower sensor inspection, egress out via the backplane out the WAN interface.
  2. WAN to LAN traffic ingress on router's WAN interface, forwarded to the backplane, get inspected by Firepower and egress out the front panel port on the UCS-E.
Step by Step Configuration
Configure CIMC
Refer the steps here: https://www.cisco.com/c/en/us/support/docs/security/firepower-management-center/200366-Configure-FirePOWER-Services-on-an-ISR-D.html#anc13
Upgrade CIMC to the latest firmware
For XE image 3.14 and above CIMC should be running 2.3 or above
For ISR IOS image 15.5(1)T and above CIMC should be running 2.3 or above
Launch CIMC GUI on the browser from the laptop with the default userID and pasword.
userID: admin and password: password
Download the latest CIMC HUU and upgrade the BIOS, CIMC and other firmware components per this link: http://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/e/2-0/gs/guide/b_2_0_Getting_Started_Guide/b_2_0_Getting_Started_Guide_chapter_01010.html#task_B4052C8757D74555A073C0BD759B211D
Setting up ESXi
Refer this link: https://www.cisco.com/c/en/us/support/docs/security/firepower-management-center/200366-Configure-FirePOWER-Services-on-an-ISR-D.html#anc16
Follow the above link to install the following as well:
Install VSphere Client
Setting up Firepower and FireSIGHT VMs
Configure VSwitch interfaces on ESXi
It is very important to click on properties for Vswitch1 and Vswitch2 and make sure to enable the following:
  1. All VLANs or atleast the one vlan that has to go through the sensor.
Click on the properties for the vswitch and add all vlans.
  1. Accept "Promiscuous Mode" for both SF-Inside and SF-Outside interfaces.
If the above is not done, then traffic will not traverse the sensor from the inside to the outside.
Spin a FireSIGHT VM and configure it
Add the FireSIGHT to the Sensor VM
Add the Sensor to the FireSIGHT
Add license to the FireSIGHT Management Center
Relevant Switch and Router Config
We increase the spanning tree port cost so that the front panel port will be preferred to receive the LAN side traffic. If the Firepower VM crashes or is shut down, then, traffic will be automatically received by the router's G0/0/1 port but traffic will be processed without being scanned by the Firepower sensor VM.
Switch Router
Enable Rapid Spanning Tree on the Switch
spanning-tree mode rapid-pvst
spanning-tree vlan 100,200 hello-time 1
spanning-tree vlan 100,200 forward-time 4
Port connected to the UCS-E Front Panel Ge 2 Port
interface GigabitEthernet1/0/1
 switchport mode trunk
  spanning-tree cost 10
Port connected to the routers G0/0/1 Port
interface GigabitEthernet1/0/24
 spanning-tree cost 100
Inside Interface Configuration no ip address here. BDI interface has the IP address
interface GigabitEthernet0/0/1
 no ip address
 negotiation auto
 service instance 100 ethernet
  encapsulation dot1q 100
  rewrite ingress tag pop 1 symmetric
  bridge-domain 100
 service instance 200 ethernet
  encapsulation dot1q 200
  bridge-domain 200
This interface is to route management traffic to ESXi and Firepower Sensor (notice the static routes below)
interface ucse0/1/0
 ip unnumbered BDI100
 no negotiation auto
 no mop enabled
 no mop sysid
We only need to vlan 200 on the outside of the sensor as only vlan 200 traffic will come in via the front panel port for inspection.
interface ucse0/1/1
 no ip address
 negotiation auto
 no mop enabled
 no mop sysid
  bridge-domain 200
BDI Interface for vlan 100
interface BDI100
 ip address 10.129.16.1 255.255.255.0
BDI Interface to terminate vlan 200 on the outside of the FP sensor
interface BDI200
 ip address 10.129.17.1 255.255.255.0
Route statements for FP-Sensor and ESXI management
ip route 10.129.16.6 255.255.255.255 ucse0/1/0
ip route 10.129.16.8 255.255.255.255 ucse0/1/0
In this example there is only one vlan traffic (200) that is sent to the sensor for inspection. In case another vlan gets added to the inside network, we need to add a corresponding BDI interface and also create a service instance on the router.
Outputs
Output from the Switch when Firepower VM is up and running
Switch#show spanning-tree vlan 100
VLAN0100
  Spanning tree enabled protocol rstp
  Root ID    Priority    32868
             Address     188b.4555.6780
             This bridge is the root
             Hello Time   1 sec  Max Age 20 sec  Forward Delay  4 sec
  Bridge ID  Priority    32868  (priority 32768 sys-id-ext 100)
             Aging Time  300 sec
Interface           Role Sts Cost      Prio.Nbr Type
Gi1/0/1             Desg FWD 4         128.1    P2p
Gi1/0/2             Desg FWD 4         128.2    P2p
Gi1/0/14            Desg FWD 19        128.14   P2p
Gi1/0/15            Desg FWD 19        128.15   P2p
Gi1/0/24            Desg FWD 4         128.24   P2p
Switch#show spanning-tree vlan 200
VLAN0200
  Root ID    Priority    32968
  Bridge ID  Priority    32968  (priority 32768 sys-id-ext 200)
             Aging Time  300 sec
Gi1/0/10            Desg FWD 19        128.10   P2p Edge
Gi1/0/12            Desg FWD 4         128.12   P2p Edge
Gi1/0/13            Desg FWD 4         128.13   P2p Edge
Output from the Router when the Firepower sensor is up and running
Router#show spanning-tree vlan 100
G1:VLAN0100
             Cost        100
             Port        2 (GigabitEthernet0/0/1)
             Address     5c83.8f49.d9f2
             Aging Time 0
Gi0/0/1             Root FWD 100       128.2    P2p
Router#sh spanning-tree vlan 200
G1:VLAN0200
             Cost        10
             Port        18 (ucse0/1/1)
             Aging Time 0
Gi0/0/1             Altn BLK 100       128.2    P2p
uc0/1/1             Root FWD 10        128.18   P2p
As you can see in the above output. G0/0/1 is in Altn BLK state. Packets will only come in and leave using the uc0/1/1 port which is in Root FWD state.
Output from the Switch when the Firepower sensor is shut down
VLAN0100
             Aging Time  300 sec
VLAN0200
             Aging Time  300 sec
Output from the Router when the Firepower sensor is shut down
G1:VLAN0100
             Cost        100
             Aging Time 0
Router#show spanning-tree vlan 200
G1:VLAN0200
             Cost        100
             Aging Time 0
uc0/1/1             Desg FWD 10        128.18   P2p
colin-turner
Hi Kureli,
Do you have the equivalent router and switch configuration for implementation using an ISR G2 router?
Many thanks,
Colin
QW_netzwerk
Hello Kureli,
we have some 4331 router with sm-x switch modules. We have configured the internal subslot as svi and configured My question is whether I need to consider something on design guideline to connect the UCS to the internal switch or we need to some confiugration change to inspect the internal vlans traffic?
Saimun
pabloarturo
Can I upgrade to version 6.2.3 the NGIPSv for ISR with an UCS-E180D-M2/K9 module ?
