davebush
The attached document will guide you through configuring a port forward on FirePower using FDM.
Martin L
Thanks for sharing!
walenteano
I really need your help on a certain configuration.
I tried deploying two FTD-2110 on my network.
After all configurations, workstation connected to vlan85 whose gateway is patched on FTD_1 could not reach a workstation on vlan_10 whose gateway is patched on FTD_2.
Both FTD are connected directed via cable.
Kindly help if i'm missing something out.
