Thanks for sharing!
Thanks for Sharing the write up.
Hey, just want to ask you if you could also explain how to enable SNMP via FDM (Cisco Firepower 1010) 6.7.
With 6.7 there is no FlexConfig for SNMP anymore and you have to use the REST API and this is nether
documented anywhere, nor are there any tutorials for SNMP configurations via API. This is ridiculously complicated.
BR
Steve
Hi, how to config the snmp via FDM using 6.7?
I'm using 6.7 version and I'm having the same issue
Please note that my documentation only works on version 6.6 and prior. (I've used it as far back as version 6.4.)
For version 6.7 or newer you will need to use @Anupam Pavithran's script from this posting.
My FP1010 is on 6.7.0 now, and thanks to Anupam I'm able to get SNMP data into my Stealthwatch Enterprise system.
