olpeleri
Systems under test
This document covers ISR G2 Cisco 3945 and Cisco 3945e routers with on-board crypto engine.
Both devices are connected back to back via GigabitEthernet0/1.
Packet injector Agilent is connected via GigabitEthernet0/2 on both routers
The version that has been tested in this lab is 15.1(4)M5.
Traffic pattern that has been sent to the router is bursty [ busts of 1000 packets sent at 1gig/second].
This flow will go through features such as Complex [Parent/Child] QoS - GRE encapsulation - Encryption / Decryption.
Crypto engine command output may differ from a 1900 or 2900, still the same logic has to be applied on other platforms.
1. 3945 - what to check
  • show proc cpu
bsns-3945-2#sh proc cpu | e 0.00%
3945#sh proc cpu | e 0.00%
CPU utilization for five seconds: 64%/63%; one minute: 62%; five minutes: 72%
PID Runtime(ms)     Invoked      uSecs   5Sec   1Min   5Min TTY Process
  16     1384592      494466       2800  0.31%  0.06%  0.02%   0 Environmental mo
  69     4263712      528295       8070  0.07%  0.09%  0.07%   0 Per-Second Jobs
  87      624592     1977539        315  0.15%  0.13%  0.11%   0 Netclock Backgro
105      327624    60431937          5  0.07%  0.09%  0.09%   0 SEC BATCH
109      155144    62150729          2  0.07%  0.11%  0.13%   0 Ethernet Msec Ti
209      359008   120354323          2  0.15%  0.13%  0.14%   0 HQF Shaper Backg
291      127524    24465492          5  0.07%  0.05%  0.06%   0 MFIB_mrib_write
295        2200         810       2716  0.15%  0.19%  0.08% 644 Virtual Exec
326      326172    11161929         29  0.07%  0.04%  0.06%   0 PIM Process
Here the CPU reports an average usage of 64% with 63% under interrupt [ aka packets routed by CEF ].
We will see later the router is in fact oversubscribed.
Key learning: CPU usage is measured as an average calculed on 5 seconds.
This is something to always remember since the real-time CPU utilization might reach 100% during few msecs and this will not be seen in any show commands.
Because of this average report, you should never take the CPU usage 'as it is', U will have to understand the traffic pattern in order to  get the right picture.
  • show platform interrupt
Per design, Interrupts [ aka packet forwarding under CEF]  have the highest priority from a scheduling standpoint.
Under load, there is a safeguard mechanism that gives to other IOS processes few msec of CPU time. This is what Interrupt throttling is used for.
3945-2#sh platform interrupt  | section Interrupt Throttling
Interrupt Throttling:
  Throttle Count    =    31065   Timer Count            =    31060
  Netint(usec)      =    20000   Netint Mask(usec)      =     1000
  Real Netint(usec) =     4000   Real Netint Mask(usec) =      200
  Active            =        0   Configured             =        1
  Longest IRQ(usec) =     8856
When 4000 usec [ 4 msec] of continuous traffic under interrupt has been reached, Net I/O interrupts will be throttled during 200 usec, giving some CPU time to processes.
If we take few consecutive outputs, we can see the throttle increasing
3945-2#terminal exec prompt timestamp
3945-2#show plat interrupt | i Time | Throttle Count
Time source is hardware calendar, 08:04:14.637 UTC Mon Oct 15 2012
  Throttle Count    =    37313   Timer Count            =    37308
bsns-3945-2#show plat interrupt | i Time | Throttle Count
Time source is hardware calendar, 08:04:17.513 UTC Mon Oct 15 2012
  Throttle Count    =    37359   Timer Count            =    37354
When we throttle [ aka ignore ] an interrupt, packets are queued on the interface and most likely dropped as overruns [ aka not polled quick enough from the interface]
  • show platform error
bsns-3945-2#show plat error
Load for five secs: 64%/63%; one minute: 64%; five minutes: 64%
Time source is hardware calendar, 08:11:10.301 UTC Mon Oct 15 2012
Interface GigabitEthernet0/1:
Input Errors            : 17529
Input Overrun           : 17529
Interface GigabitEthernet0/2:
Input Errors            : 489481
Input Overrun           : 489481
Indeed,we can see traffic getting dropped on Gigabit Ethernet 0/1 due to the burstiness of the flow. We can crosscheck by taking the interface stats
3945-2#sh int gig0/1
Load for five secs: 64%/63%; one minute: 60%; five minutes: 60%
Time source is hardware calendar, 08:14:53.261 UTC Mon Oct 15 2012
GigabitEthernet0/1 is up, line protocol is up
  Hardware is PQ3_TSEC, address is 0007.7dfb.6e01 (bia 0007.7dfb.6e01)
  Description: Connected to bsns-2960-1
  Internet address is 172.146.1.2/30
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
     reliability 169/255, txload 4/255, rxload 1/255
  Keepalive set (10 sec)
  Full Duplex, 1Gbps, media type is RJ45
  output flow-control is unsupported, input flow-control is unsupported
  Last input 00:00:00, output 00:00:00, output hang never
  Last clearing of "show interface" counters 00:03:45
  Input queue: 0/75/54785/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: Class-based queueing
  Output queue: 0/1000/0 (size/max total/drops)
  30 second input rate 2612000 bits/sec, 2177 packets/sec
  30 second output rate 17442000 bits/sec, 14535 packets/sec
     463075 packets input, 69454186 bytes, 0 no buffer
     Received 32 broadcasts (0 IP multicasts)
     0 runts, 0 giants, 392 throttles
     1082575 input errors, 0 CRC, 0 frame, 1082575 overrun, 0 ignored
     0 watchdog, 12 multicast, 0 pause input
     2407704 packets output, 361152652 bytes, 0 underruns
     8 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
We can see the overruns increasing and that we are throttling this interface. [ We see similar outputs on gig0/2].
  • Crypto engine statistics
3945-2#sh crypto engine accelerator statistic | i Error
Errors:
Pad Error                    = 0
Data Error                   = 0
Packet Error                 = 0
Null IP Error                = 0
Hardware Error               = 0
Link Down Error              = 0
Queue Full Error             = 0
API Request Error            = 0
Invalid Flow Error           = 0
QOS Queue Full Error         = 0
Packet too Big Error         = 0
Too Many Particles Error     = 0
Input Queue Full Error       = 0
Output Queue Full Error      = 0
Pre-batch Queue Full Error   = 0
Post-batch Queue Full Error  = 0
In this test scenario, crypto engine is still in healthy state since no drops are reported. Depending of the traffic pattern, it still possible to fill up the queue [ eg a burst of packets to decrypt]
3945-2#sh crypto engine accelerator ring pool | i used
The no entries currently being used   = 996
On 3945, the number of entries used on the crypto engine encryption/decryption ring is 1024 [ queue lenght] - 996 [ remaining free queue items] =28
2. What to check on the 3945e
On  an 3945e, the output from the show crypto engine accelator statistics gives a slightly different output
  • show proc cpu
3945e-1#sh proc cpu | e 0.00%
CPU utilization for five seconds: 19%/17%; one minute: 18%; five minutes: 32%
  16     1392544      500615       2781  0.63%  0.12%  0.06%   0 Environmental mo
  69     4264372      534582       7977  0.07%  0.10%  0.08%   0 Per-Second Jobs
  87      626064     2002190        312  0.23%  0.19%  0.18%   0 Netclock Backgro
109      156864    62926488          2  0.07%  0.07%  0.07%   0 Ethernet Msec Ti
209      360772   121869657          2  0.07%  0.08%  0.09%   0 HQF Shaper Backg
291      127736    24772141          5  0.07%  0.03%  0.04%   0 MFIB_mrib_write
326      327060    11302145         28  0.07%  0.04%  0.05%   0 PIM Process
CPU usage looks way better. Still, since the traffic is bursty we need to check if there is any interrupt throttling
bsns-3945e-1#sh platform interrupt  | section Throttl
Interrupt Throttling Statistics:
Throttle Count   = 00002186   Timer Count = 00002186
Few interrupt have been throttled but it never reached a drop level [ packets were simply queued and then processed]
There is no show platform error on 3945e platform. Still we can gather the info from the traditionnal show interface command
  • show interface
3945e-1#sh interfaces  | i Gigabit|over
GigabitEthernet0/0 is up, line protocol is up
GigabitEthernet0/2 is up, line protocol is up
Show interface does not reveal any issues.
945e-1#sh crypto engine accelerator statistic  | section ipsec
        Received pkts(ipsec)          : 930037
        Reinjected pkts(ipsec)        : 930036
        Dropped pkts(ipsec)           : 0
        Drop over capacity(ipsec)     : 0
        Drop no particle(ipsec)       : 0
        Drop no session(ipsec)        : 0
        Errors(ipsec)                 : 0
        Pending pkts(ipsec)           : 0
On the 3945e, no issues are seen. On this platform, the encryption/decryption queue most of the time empty.
3945e-1#sh crypto engine accelerator ring pool
Device:   Onboard VPN
The Crypto Packet IPSEC Queue Information
The Queuesize is                          :2048
The no of entries currently being used    : 0
The Read Index is                         :1809
The Write Index is                        :1809
Conclusion:
Even if on 5 seconds average, the CPU usage is not at 90+%, the nature of the traffic can create a port speed burst that lasts few msec.
During that time, a router may have issues polling each interface [ which leads to overruns].
Always size your router accordingly to the nature of the traffic or shape the flow on the next hop device on the LAN side [ in order to queue packets instead of dropping them as overruns on the ipsec gateway.
Great contribution Olivier, thanks!!
