How To: Using dCloud and ISE with a Mobility Express Controller
288
    The following document will enable you to add a Mobility Express Controller to your ISE instance in dCloud.
    You will need a dCloud ERK (Endpoint Router Kit) to be able to use the Mobility Express controller with the dCloud Mobility Deep Dive demo.
    This validation was done with the following models:
    3802l
    The Secure Access Wizard does not provision the ME-Controller but could be used if you run the Secure Access Wizard Demo and then add the ME Controller to ISE with same WLANs. This hasn't been validated and we will not go through that in this document.
    Reference docs:
    Use the Configuring Cisco Mobility Express AP with ISE as a general configuration guide for Mobility express starting with 8.7 code
    The Cisco Mobility Express Deployment Guide shows how to convert AP to ME
    Connect your AP behind your dcloud Endpoint Router Kit or into a POE switch connected behind it. The POE port will need to be in the data plan associated with your demo
    if the AP is not setup as mobility express you will need to do the following:
    MAYBE Shut off your vWLC in dcloud so the ME doesn’t connect to it. You want your ME AP to be the controller.
    Connect to WKST1. Launch browser and download the ME controller files needed per the guide depending on your AP model and state. Mine was connected to my dcloud WLC so i had to do the following
    Download mobility express software for my AP 3800 (note 8.7 code is supported with ISE COA, URL redirect, etc)
    I  put the file in the TFTP64 directory which is the root
    Try to ping WKST1 TFTP64 198.18.133.36
    Convert your AP to be a controller
    ap-type mobility-express tftp://YOUR TFTP address/<filename of TAR file with path from root on the TFTP server>
    ap-type mobility-express tftp://198.18.133.36/AIR-A3800-K9-ME-8-7-106-0.tar
    When running the MEAP setup wizard
    username/password admin/C1sco12345
    management ip from DHCP
    management DHCP scope? unknown
    Setting up an SSID is just for basic setup and is not used with ISE - this doesn’t matter, just moving past the screen
    Employee network name: mymeap
    security ENTER for PSK
    key C1sco12345
    other stuff use defaults
    Now you should get a Cisco Controller prompt
    login
    ping ise at 198.18.133.27
    This means management is able to get to ISE
    Add your controller to ISE in dCloud
    show interface summary
    the management IP comes from the data vlan for your dcloud demo
    Add ME controller to ISE
    WKST1 launch firefox and login to ISE
    Administration > Network Resources > Network Devices
    Add a network device
    Enter your AP management IP address
    Check the box to enable RADIUS Authentication Settings
    Enter shared secret C1sco12345
    Submit the page
    Launch another tab and connect to your MEAP https//ipaddress
    Login with admin creds
    Switch to expert View
    COPY FROM HOSUK’s doc
    ISE IP Address 198.18.133.27
    Only do the guest portion to show its working
    need to copy the url from the WLC when setting up the WLAN
    example: me_cwa_acl_redirect_1
    Skip SECURE/BYOD network
    Need to modify the authorization profile for the guest policies using the
    Policy > Policy Elements > Results > Authorization > Authorization Profiles
    Duplicate the HOTSPOT_REDIRECT Profile and name it HOTSPOT_REDIRECT_ME
    under the Common Tasks > Web Redirection change the ACL to the same one found when you created your WLAN
    Also make sure your Value has a portal selected
    Hotspot Guest Portal (default)
    Submit the profile
    Navigate to Policy > Policy Sets > Guest Access > View the policy set
    Expand the authorization policy
    find the Hotspot Redirect and change the Results/Profiles to HOTSPOT_REDIRECT_ME
    Save the policy
    Save off your dCloud session. This can be used over and over again. If you move your mobility express controller behind another ERK then you will need to update your ISE Network Access Device with the new IP Address. This is because each dCloud router has their own private network
