Content
For an offline/printed copy of this document, simply choose Options > Printer Friendly Page.
You may then Print or Print to PDF or copy and paste to Word or any other document format you like.
Introduction
Cisco Catalyst 9800 (C9800) series wireless controller configuration is different from AireOS and this document shows how to configure C9800 to work with ISE. For more information on Cisco Catalyst 9800 series, please go to: https://www.cisco.com/c/en/us/products/wireless/catalyst-9800-series-wireless-controllers/index.html
Setup
Components used:
WLC: Catalyst 9800-CL running 16.10.1
AP: Cisco 1815i
ISE: 2.4p3 (Previous versions of ISE should work with C9800 as well)
The document does not cover details on how to bootstrap the ISE, C9800, and AP. The document assumes the C9800 is accessible from the management PC and AP is associated to the C9800. The document also assumes underlying network elements are already configured, which includes, VLANs, SVIs, Subnets, DHCP, routing, and DNS. The following diagram and table shows settings for the components.
C9800 IP |
192.168.201.61 |
ISE IP |
192.168.201.93 |
DNS IP |
192.168.201.71 |
OPEN SSID |
OPEN |
SECURE SSID |
SECURE |
Guest VLAN |
30 |
Guest Subnet |
192.168.30.0/24 |
User VLAN |
10 |
User Subnet |
192.168.10.0/24 |
Notes:
- If static ACL needs to be applied to a session, use AireSpace-ACL-Name (6) attribute to send down a ACL name. The ACL needs to be pre-created on C9800
- If dVLAN needs to be applied to a session, use AireSpace-VLAN-Name (5) attribute to send down a VLAN name/ID. The VLAN needs to be pre-created on C9800. Alternatively standard RADIUS 3 tuple attributes can be used for VLAN assignment using VLAN name/ID
- Redirect ACL follows Catalyst IOS syntax instead of AireOS syntax. So permit statement means the matching traffic is redirected, while deny means it will be allowed without redirect
- With local mode, unlike AireOS, DNS ACL entries are not tied to the redirect ACL. URL entries needs to be defined in the URL Filters and called upon via separate RADIUS attribute during the authentication. More information on this at the end of the document on ISE section.
- With FlexConnect mode, URL filter is tied to the redirect ACL within the flex profile, so URL filter does not need to be called upon via separate RADIUS attribute
- URL redirect feature requires that the http (optionally https) server service on the 9800 be enabled. It is enabled by default but to enable it run 'ip http server' (For HTTP redirect) and 'ip http secure-server' (For HTTPS redirect)
Catalyst 9800 Configuration
Following diagram shows the C9800 configuration at a high level. Each box represents individual configuration profile with relevant options shown and how each profile feeds into other profiles to make a working configuration. The bullet points within the profile that are in bold represents sub profile being fed into the profile. It also includes the suggested order to create the profiles that maps to the main section of the document.
Steps 1 - 3: Define AAA
- Go to Configuration > Security > AAA > Servers / Groups > Servers, Click Add
Enter following information (Any configuration not defined in the table assumes default settings):
Name
ISE01 |
IP |
192.168.201.93 |
Key |
***** (Match with ISE) |
Support for CoA |
Checked |
- Click Server Groups, Click Add
Enter following information:
Name
ISE |
Available Servers |
ISE01 |
- Go to Configuration > Security > AAA > AAA Method List > Authentication, Click Add
Create Authentication list using following information that will be used for both OPEN SSID and SECURE SSID:
Name
default |
Type |
dot1x |
Group-Type |
Group |
Available Server Groups |
ISE |
Note: If clients are failing to associate and authentication request does not show up on ISE Live Log, try setting the authentication list name to 'default' as shown above.
Go to Configuration > Security > AAA > AAA Method List > Authorization, Click Add
- Enter following information for AAA Authorization list that will be shared for both SSIDs:
Name
default |
Type |
Network |
Group-Type |
Group |
ISE |
Note: The Authorization name 'default' is significant here since there is no Authorization list that can be defined within the 802.1X WLAN. By using 'default' as name, C9800 can use the ISE to get additional authorization. If default authorization list cannot be used or desired, then named authorization can be created and can be referenced via RADIUS server as a Cisco VSA. The Cisco VSA to use is 'Method-List={authorization-method-list}', which can be configured in ISE advanced Attribute Settings. Please see examples at the end of the document.
- Go to Configuration > Security > AAA > AAA Method List > Accounting, Click Add
Name
default |
Type |
Identity |
ISE |
Step 4: Create Webauth Parameter Map (Required for BYOD)
This will only be used in the SECURE SSID to suppress Apple CNA (AKA mini browser) from popping up upon association to the WLAN. This is required as the Apple CNA is unable to fulfill the BYOD onboarding flow.
- Go to Configuration > Security > Webauth > Webauth Parameter Map, Click Add
- Enter Name ‘Captive-Bypass-Portal, Click Apply to Device
- Click ‘Captive-Bypass-Portal’ parameter map from the list
- Check Captive Bypass Portal, Click Update & Apply
Step 5: Create VLANs
- Go to Configuration > Layer 2 > VLAN > VLAN, Click Add
- Add two VLANs using following table for User VLAN and Guest VLAN. These VLANs will be mapped to SECURE SSID and OPEN SSID respectively using policy profiles and tags:
VLAN ID |
10 |
30 |
Name |
User |
Guest |
State |
Activated |
Activated |
Port Members |
Gi2 |
Gi2
- Click Save & Apply to Device
Step 6: Create WLANs
- Go to Configuration > Tags & Profiles > WLANs, Click Add
- Add WLANs using following table for OPEN WLAN and SECURE WLAN. These WLANs will be mapped to the AP using tags (Any configuration not defined in the table assumes default settings):
General |
Profile Name |
OPEN |
SECURE |
SSID |
OPEN |
SECURE |
Status |
Enabled |
Enabled |
Security > Layer 2 |
Layer 2 Security Mode |
None |
WPA + WPA2 |
MAC Filtering |
Enabled |
Authorization List |
default |
Security > Layer 3 |
Webauth Parameter Map |
Captive-Bypass-Portal |
Security > AAA |
Authentication List |
default |
default |
Note: There is no reference to Authorization List for 'SECURE' SSID. This is not an issue for AAA override operation that applies authorization directly from RADIUS ACCESS-ACCEPT response. However, this is an issue for applying authorization as it requires additional RADIUS communication which requires authorization list. To address this issue, either use special name 'default' as authorization list as configured above or configure ISE to send Cisco VSA 'Method-List={authorization-method-list}' with ACCESS-ACCEPT. See ISE section below for more information.
Step 7: Create Policy Profiles
- Go to Configuration > Tags & Profiles > Policy, Click Add
- Add Policy Profiles for both WLANs using following table. Policy profile covers device sensor, default VLAN, CoA, and RADIUS Accounting. Since VLANs are different, two profiles are created one for each WLAN. These profiles will be mapped to the WLANs using tags (Any configuration not defined in the table assumes default settings):
General |
Name |
Guest |
User |
Status |
Enabled |
Enabled |
Access Policies |
HTTP TLV Caching |
Checked |
Checked |
RADIUS Profiling |
Checked |
Checked |
DHCP TLV Caching |
Checked |
Checked |
VLAN/VLAN Group |
Guest |
User |
Advanced |
Allow AAA Override |
Checked |
Checked |
NAC State |
Checked |
Checked |
Accounting List |
default |
default |
Note: For device sensor based ISE profiling to work make sure to enable RADIUS profiling, HTTP TLV Caching, DHCP TLV Caching, and Accounting List in the policy profile
Step 8: Create Policy Tag
- Go to Configuration > Tags & Profiles > Tags, under Policy Click Add
- Enter Name: ISE Enabled
- Within the 'ISE Enabled' Tag window, click Add to map following WLANs to matching policy profiles. This ties the WLAN to the respective Policy Profile.
WLAN Profile |
Policy Profile |
OPEN |
Guest |
SECURE |
User |
Step 9: Assign Policy Tag to AP
Finally, apply the tag to the AP. This section shows instructions on tying it to a single AP. Using Advanced Wireless Setup Wizard on C9800, same tag can be applied to multiple APs at the same time.
- Go to Configuration > Wireless > Access Points
- Click on the AP Name or MAC address
- Under General > Tags, Select 'ISE Enabled'
- Click Update & Apply to Device
Step 10a: Create Redirect ACL for Guest flow
- Go to Configuration > Security > ACL, Click Add
- Use ACL Name: ACL_WEBAUTH_REDIRECT
- For ACL Type, select IPv4 Extended
- Enter following rules in the ACL for Guest only access redirect ACL
Sequence |
Action |
Source IP |
Destination IP |
Protocol |
Source Port |
Destination Port |
10 |
deny |
any |
192.168.201.93 |
tcp |
eq 8443 |
20 |
deny |
any |
192.168.201.71 |
udp |
eq domain (53) |
30 |
permit |
any |
any |
tcp |
eq www (80) |
Step 10b: Create Redirect ACL for BYOD flow
- Enter following rules in the ACL for Guest and BYOD (Sequence 20 is needed for any endpoints using Network Setup Assistant for BYOD)
Sequence |
Action |
Source IP |
Destination IP |
Protocol |
Source Port |
Destination Port |
10 |
deny |
any |
192.168.201.93 |
tcp |
eq 8443 |
20 |
deny |
any |
192.168.201.93 |
tcp |
eq 8905 |
30 |
deny |
any |
192.168.201.71 |
udp |
eq domain (53) |
40 |
permit |
any |
any |
tcp |
eq www (80) |
Step 11a: Create URL Filter for BYOD flow
Unlike AireOS which allows DNS entries to be part of redirect ACL, separate URL filter have to be created and be called upon via RADIUS attribute from ISE to permit access to Internet hosts using FQDNs.
- Go to Configuration > Security > URL Filters, Click Add
- Add URL Filter using following table (Example here is to allow access to Google Play store for BYOD):
Name |
BYOD-URL-Filter |
Type |
PRE-AUTH |
Action |
Permit |
URLs |
*.google.com accounts.youtube.com gstatic.com *.googleapis.com *.appspot.com ggpht.com gvt1.com market.android.com android.pool.ntp.org *.googleusercontent.com *.google-analytics.com |
Note: The PRE-AUTH URL filter always works as if the 'Action' is Permit regardless of whether it is setup as Permit or Deny.
Step 11b: Create URL Filter for Social Network Guest access - Facebook
- Add URL Filter using following table (Example here is to allow access to Facebook OAUTH2 login for Guest access):
Name |
Guest-URL-Filter |
Type |
PRE-AUTH |
Action |
Permit |
URLs |
*.facebook.com *.akamai.com *.fbcdn.net *.akamaihd.net |
ISE Configuration
Authorization Profile with URL Filter
Policy Setup on ISE is identical to the one for AireOS controller aside from the URL ACL that needs to be defined as separate RADIUS attribute. This is done by sending Cisco VSA "url-filter-preauth={URL_Filter_Name}". Here is an example of ISE Authorization profile for BYOD that allows Android devices to access the Google play store using the pre-auth URL filter defined above. Note the Cisco AV pair defined in the 'Advanced Attribute Settings' section.
For rest of the ISE configuration, please use following guide for rest of the ISE configurations:
Guest: https://community.cisco.com/t5/security-documents/ise-guest-access-prescriptive-deployment-guide/ta-p/3640475
BYOD: https://community.cisco.com/t5/security-documents/cisco-ise-byod-prescriptive-deployment-guide/ta-p/3641867
Posture: https://community.cisco.com/t5/security-documents/ise-posture-prescriptive-deployment-guide/ta-p/3680273
Catalyst 9800 Configuration for FlexConnect Local switching
This section describes additional configuration needed to configure the WLAN as FlexConnect Local switching and integrate it with ISE. This section will utilize existing configurations made above.
Modify Policy Profile
- Go to Configuration > Tags & Profiles > Policy, Click profile name that maps to the WLAN to change to local switching
- Under WLAN Switching Policy section, uncheck Central Switching
- Repeat above steps for other policy profiles that maps to the WLANs to be converted to local switching
Create Flex Profile
- Go to Configuration > Tags & Profiles > Flex, Click Add
- Add Flex Profile using following table
General |
Name |
Flex |
Policy ACL |
ACL Name |
ACL_WEBAUTH_REDIRECT |
Central WebAuth |
Checked |
Pre Auth URL Filter |
(If this is for BYOD, select BYOD-URL-Filter, else blank) |
VLAN |
VLAN Name |
User |
Guest |
VLAN Id |
10 |
30 |
Note: When 'Central WebAuth' is checked, the C9800 automatically creates a Flex ACL that is in reverse of selected redirect ACL. The permit statements are changed to deny and deny statements are changed to permit. This is due to differences between the two redirect ACL types and slight modification is needed on the ACL to make it work with FlexConnect mode. This option should only be checked for ACL that is going to be used for redirect purpose and for post-authentication ACL, this option should not be checked. See ACL section below for more information.
Create Site Tag
- Go to Configuration > Tags & Profiles > Tags, Click Site, Click Add
- Add Site Tag using following table
Name |
Branch |
Flex Profile |
Flex |
Enable Local Site |
Unchecked |
Note: Unchecking 'Enable Local Site' will reveal Flex Profile option
Assign Site Tag to AP
- Under General > Tags > Site, Select 'Branch'
Note: The AP will disconnect for few minutes and when reconnected to the controller, it will be in FlexConnect mode
Modify Redirect ACL
When ACL is translated to the FlexConnect ACL, it requires return traffic to be allowed for it to work. If deny is missing for return traffic the endpoint in Central_WebAuth state will not be able to finish the redirect flow. Following changes to the existing ACL will make ACL wotk for both local mode and FlexConnect mode.
- Go to Configuration > Security > ACL, Click ACL name ACL_WEBAUTH_REDIRECT
- For any deny statement ensure that deny ACE entry is added for return traffic. See sequence 11 & 12 for example:
Sequence |
Action |
Source IP |
Destination IP |
Protocol |
Source Port |
Destination Port |
10 |
deny |
any |
192.168.201.93 |
tcp |
eq 8443 |
11 |
deny |
192.168.201.93 |
any |
tcp |
eq 8443 |
20 |
deny |
any |
192.168.201.71 |
udp |
eq domain (53) |
21 |
deny |
192.168.201.71 |
any |
udp |
eq domain (53) |
30 |
permit |
any |
any |
tcp |
eq www (80) |
Troubleshooting
For more information on the C9800/ISE integration and troubleshooting, please go to: https://www.cisco.com/c/en/us/support/wireless/catalyst-9800-series-wireless-controllers/products-configuration-examples-list.html
