MARS restore problem
1036
after reimage MARS i have problem with configuration restore
please help
[pnadmin]$ pnrestore -m1 -pXXX.XXX.XXX.XXX:/nfs -sXXX.XXX.XXX.XXX:/nfs
cannot obtain signal handler
ACE_Service_Config::open: Success
Thread 1024:PN-0100:Opened Oracle connection
Thread 1024:PN-0012:Created 'DbClient' instance
Thread 1024:PN-0101:Closed Oracle connection
Thread 1024:PN-0013:Deleted 'DbClient' instance
Thread 1024:Param Name is SCHEMA_VERSION, the value is 4360.
Thread 1024:Param Name is PRODUCT_VERSION, the value is 436.
Thread 1024:Param Name is OS_VERSION, the value is 0.
Thread 1024:Mounting  remote NFS path successfully!
It is going to take a while if data volume is large ...
Thread 1024:PN-0013:Deleted 'PnLogger' instance
[pnadmin]$ nd between date  and
Thank you for your posting and interest in the Cisco Support Community.  For best practices on posting documents in this community you can refer to
https://supportforums.cisco.com/docs/DOC-6022#Can_I_use_documents_to_post_technical_questions
For technical questions related to a Cisco Product or Technology, we encourage you to post on the Network Professionals Forum (NetPro). For your question on <specify Cisco Product or technology> you can go to <put the link to the specific forum, e.g. if the question is related to MARS troubleshoot, put the post in General under Security
Create
Recognize Your Peers
Content for Community-Ad
