Introduction
This document provides an example of TACACS+ authentication configuration on a Nexus switch. By default, if you configure the Nexus switch in order to authenticate through Access Control Server (ACS), you are automatically placed in the network-operator/vdc-operator role, which provides read-only access. In order to be placed in the network-admin/vdc-admin role, you need to create a shell on the ACS 5.2. This document describes that process.
Prerequisites
Requirements
Ensure that you meet these requirements before you attempt this configuration:
- Define your Nexus switch as a client in ACS.
- Define the IP address and an identical shared secret key on the ACS and Nexus.
Note: Create a checkpoint or a backup on Nexus before you make any changes.
Components Used
The information in this document is based on these software and hardware versions:
- ACS 5.2
- Nexus 5000, 5.2(1)N1(1)
The information in this document was created from the devices in a specific lab environment. All of the devices used in this document started with a cleared (default) configuration. If your network is live, make sure that you understand the potential impact of any command.
Conventions
Refer to the Cisco Technical Tips Conventions for more information on document conventions.
Configure
In this section, you are presented with the information to configure the features described in this document.
Note: Use the Command Lookup Tool (registered customers only) to obtain more information on the commands used in this section.
Nexus Device for Authentication and Authorization with ACS 5.2 Configuration
Complete these steps:
- Create a local user on the Nexus switch with full privileges for fallback:
username admin privilege 15 password 0 cisco123!
- Enable TACACS+, then provide the IP address of the TACACS+ Server (ACS):
feature tacacs+tacacs-server host IP-ADDRESS key KEY
tacacs-server key KEY
tacacs-server directed-request
aaa group server tacacs+ ACS
server IP-ADDRESS
use-vrf management
source-interface mgmt0
Note: The key must match the shared secret configured on the ACS for this Nexus device.
- Test the TACACS server availability:
test aaa group group-name username password
The test authentication should fail with a reject message from the server, since the server has not been configured. This reject message confirms that the TACACS+ server is reachable.
- Configure login authentications:
aaa authentication login default group ACSaaa authentication login console group ACS
aaa accounting default group ACS
aaa authentication login error-enable
aaa authorization commands default local
aaa authorization config-commands default local
Note: Nexus uses local authentication if the authentication server is unreachable.
ACS 5.x Configuration
- Navigate to Policy Elements > Authentication and Permissions > Device Administration > Shell Profiles in order to create a Shell Profile.
- Enter a name for the profile.
- Under the Custom Attributes tab, enter these values:
Attribute: cisco-av-pair
Requirement: Mandatory
Value: shell:roles*"network-admin vdc-admin"
- Submit the changes in order to create an attribute-based role for the Nexus switch.
- Create a new authorization rule, or edit an existing rule, in the correct access policy. By default, TACACS+ requests are processed by the Default Device Admin access policy.
- In the Conditions area, choose the appropriate conditions. In the Results area, choose the Nexus OS shell profile.
- Click Ok.
Verify
Use this section to confirm that your configuration works properly.
The Output Interpreter Tool (registered customers only) (OIT) supports certain show commands. Use the OIT to view an analysis of show command output.
Related Information
#Please post comments if there are any queries and rate if useful
