Remediation Module for Security Intelligence Blacklist
7501
Remediation module for automatically adding an IP address to a Security Intelligence blacklist. The file contains a readme with more information.
esersekizinci
Beginner
Hi, I wanted to make this remediation tool much more automatize, script add the IP address into the black_list automatically but if you want to clear list or remove the IP addresses you have to delete manually
In this cron job script you can remove all the IP addresses automatically in every 4 hours.
vim /tmp/clear_custom_list.sh
rm /var/sf/htdocs/custom_blacklist.html
echo "Dosya silindi $(date)"
sleep 2
cat > /var/sf/htdocs/custom_blacklist.html
echo "Dosya olusturuldu $(date)"
sleep 2
sudo md5sum /var/sf/htdocs/custom_blacklist.html > /var/sf/htdocs/custom_blacklist_md5.html
echo "Hash hesaplandi $(date)"
crontab -e
0 */4 * * * /tmp/clear_custom_list.sh >> /tmp/custom_list_log.log 2>&1
! Make it executable
chmod +x /tmp/clear_custom_list.sh
You can see the logs with timestamp
root@fmc623:/tmp# cat custom_list_log.log
Dosya silindi Sat May 25 12:53:01 UTC 2019
Dosya olusturuldu Sat May 25 12:53:03 UTC 2019
Hash hesaplandi Sat May 25 12:53:05 UTC 2019
Cheers !
ermal
Beginner
I use FMC 6.2.3.15, and i have installed and configured remediation module blacklist v1.1.
Source IPs detected from correlation events, are written on the file auto_blacklist.html and also the md5 file value changes.
The problem that i have is that the Network Feed that i have created does not receive updates from this list. I get the error message "Unable to download File"
Please find below a screenshot of the configuration of the Network Feed.
Any idea?
marcairn
If you SSH into your FMC and go to expert mode, then change into the proper html directory, do you see your file with the exact name "auto_blacklist.html"?
In my case, as it stands right now:
admin@fmc:/$ cd /var/sf/htdocs
admin@fmc:/var/sf/htdocs$ ls -l scanners.html
-rw-r--r-- 1 root root 15696 Mar 6 13:46 scanners.html
Also, as a test, you should be able to open a browser tab and hit the URL that you are trying to parse and see the IPs in the file.
ermal
Beginner
Thanks for your response marcairn.
When i ssh into fmc i can see the file with the exact name, also dhe md5.html file in the /var/sf/htdocs.
Right now i don't have access to the device, but on Monday I'll check if i can access this file from a browser.
Do i have to run/enable any web service on FMC?
ermal
Beginner
I've used the https://FMC_Hostname/auto_blacklist.html and now the list is OK with the update :)
Now i have another question: Is there any way to set Update Frequency of this list 5 minutes, or less?
marcairn
Glad to hear things are working.
30 minutes is the minimum update time for a custom feed.
Mark
ermal
Beginner
Thanks a lot :)
is it working for FMC 6.4. version ?
marcairn
siddharthjaiswal@live.com
Yes. I have been using the blacklist remediation up through the current 6.6 release.
pioneer01
Beginner
I have a new install of FMC 6.5 and am having trouble similar to ermal. However i can't reach it via the web address and the files don't exist in '/var/sf/htdocs' either. Any suggestions?
ermal
Beginner
Hi pioneer01,
You have to trigger a correlation event, and this will create and also fill the list.
After that you will see it on "/var/sf/htdocs", and also access through web interface.
Br.
Create
Recognize Your Peers
Polls
Which of these topics should we host an event in the Community?
Top Choice: pxGrid (36%)
Content for Community-Ad
