Remote VPN Clients connected through ASA do not authenticate with Microsoft Active Directory and Split tunneling does not work
603
Core issue
These debug messages appear when you enable the debug crypto isakmp  command on ASA during the remote access clients authentication.
IKEv1]: Group = ani, Username = , IP = x.x.x.x, Removing peer
from peer table failed, no match!
[IKEv1]: Group = ani, Username = , IP = x.x.x.x, Error: Unable
to remove PeerTblEntry
Resolution
For a workaround, complete these steps:
  1. Check the configuration for these commands:
  2. Make sure that Split tunnel and relevant access-lists are configured properly.
Refer to PIX/ASA 7.x: Enhanced Spoke-to-Client VPN Configuration for information on how to configure a spoke-to-client VPN tunnel on the PIX Firewall
Third Party Software
Windows Active Directory
VPN Tunnel End Points
ASA
Client
Features & Tasks
Authentication, Authorization, Accounting (AAA)
VPN Protocols
Split tunneling
Content for Community-Ad
