This demo illustrates the use of SSO using ISE contextual information for SAML insertion and using ISE authorization polices for differentiated access.
I have question when integrating cisco ISE with Aruba switches. Does policy based automation will be working with aruba JL256A switch? Thanks in advance
Hello. I'm trying to implement a tunnel between two endpoints in a IPv6 network, using IPSEC.The tunnel establishes correctly: I used wireshark to see the IKE packets during the negotiation.The problem is, pings are not going through the tunnel correctly....
view more
HiAmy ideas whats causing this please |i have recently added a new Cert on the other end of the tunnel RTR. ?? .May 21 16:48:11.108: %CRYPTO-4-RECVD_PKT_INV_SPI: decaps: rec'd IPSEC packet has invalid spi for destaddr=X.X.X.X, prot=50, spi=0x4E128779...
view more
Radius server configuration for 802.1X
Server radius test1
Address ipv4 10.1.1.1
Key 1234
Server radius test2
Address ipv4 10.1.1.2
Key 1234
aaa group server radius TEST-gr
server name test1
server name test2
view more
Umbrella’s cloud-delivered firewall (CDFW) is a cool features that provides Firewall Services in the Cisco Umbrella Cloud without the need to deploy on-premises firewall devices and visibility and control for internet traffic across all branch offices. To...
view more
