Martin_DK
Community Member
Hi There
We have a strange Lan to Lan problem.
Its a Pix 501 and a VPN3000, it have worked perfectly for 2 years but now users are diconnected randomly.
When I do a ping from pix to vpn3000 or the other way without traffic on the tunnel its ok, but when I make a simple telnet "IP" 3050 the ping time out one or two times? also a RDP logon session to a server thought the tunnel gives timeout.
It seems that one data session can ruin it for all the others.
When using a VPN software client either way gives no problem, so its not the line.
Is there anyone who have seen this problem before and know what I should look for?
Martin
