i replace a 2621XM router with a 2901 Router, now i have e problem with the Cisco VPN Client Version 5
The connection hangs on State IKE_R_AM2 but i don't know why.
Note: Static IPSEC connections works.
Thanks for your help
Michael.
Sep 12 23:46:15 8868: Sep 12 23:46:15: ISAKMP:(0):Fill atts in sa vpi_length:4
Sep 12 23:46:15 8869: Sep 12 23:46:15: ISAKMP:(0):Fill atts in sa life_in_seconds:2147483
Sep 12 23:46:15 8870: Sep 12 23:46:15: ISAKMP:(0):Returning Actual lifetime: 86400
Sep 12 23:46:15 8871: Sep 12 23:46:15: ISAKMP:(0)::Started lifetime timer: 86400.
Sep 12 23:46:15 8872:
Sep 12 23:46:15 8873: Sep 12 23:46:15: ISAKMP:(0): processing KE payload. message ID = 0
Sep 12 23:46:15 8874: Sep 12 23:46:15: ISAKMP:(0): processing NONCE payload. message ID = 0
Sep 12 23:46:15 8875: Sep 12 23:46:15: ISAKMP:(0): vendor ID is NAT-T v2
Sep 12 23:46:15 8876: Sep 12 23:46:15: AAA/AUTHOR (0x24): Pick method list 'groupauthor'
Sep 12 23:46:15 8877: Sep 12 23:46:15: ISAKMP:(0):Input = IKE_MESG_FROM_PEER, IKE_AM_EXCH
Sep 12 23:46:15 8878: Sep 12 23:46:15: ISAKMP:(0):Old State = IKE_READY New State = IKE_R_AM_AAA_AWAIT
Sep 12 23:46:15 8879:
Sep 12 23:46:15 8880: Sep 12 23:46:15: AAA SRV(00000024): process author req
Sep 12 23:46:15 8881: Sep 12 23:46:15: AAA SRV(00000024): Author method=LOCAL
Sep 12 23:46:15 8882: Sep 12 23:46:15: AAA SRV(00000024): protocol reply PASS for Authorization
Sep 12 23:46:15 8883: Sep 12 23:46:15: AAA SRV(00000024): Return Authorization status=PASS
Sep 12 23:46:15 8884: Sep 12 23:46:15: ISAKMP:(1033): constructed NAT-T vendor-02 ID
Sep 12 23:46:15 8885: Sep 12 23:46:15: ISAKMP:(1033):SA is doing pre-shared key authentication plus XAUTH using id type ID_IPV4_ADDR
Sep 12 23:46:15 8886: Sep 12 23:46:15: ISAKMP (1033): ID payload
Sep 12 23:46:15 8887: next-payload : 10
Sep 12 23:46:15 8888: type : 1
Sep 12 23:46:15 8889: address : 134.1.2.81
Sep 12 23:46:15 8890: protocol : 0
Sep 12 23:46:15 8891: port : 0
Sep 12 23:46:15 8892: length : 12
Sep 12 23:46:15 8893: Sep 12 23:46:15: ISAKMP:(1033):Total payload length: 12
Sep 12 23:46:16 8894: Sep 12 23:46:15: ISAKMP:(1033): sending packet to 91.62.130.220 my_port 500 peer_port 51041 (R) AG_INIT_EXCH
Sep 12 23:46:16 8895: Sep 12 23:46:15: ISAKMP:(1033):Sending an IKE IPv4 Packet.
Sep 12 23:46:16 8896: Sep 12 23:46:15: ISAKMP:(1033):Input = IKE_MESG_FROM_AAA, PRESHARED_KEY_REPLY
Sep 12 23:46:16 8897: Sep 12 23:46:15: ISAKMP:(1033):Old State = IKE_R_AM_AAA_AWAIT New State = IKE_R_AM2
Sep 12 23:46:16 8898:
Sep 12 23:46:26 8899: Sep 12 23:46:25: ISAKMP:(1033): retransmitting phase 1 AG_INIT_EXCH...
Sep 12 23:46:26 8900: Sep 12 23:46:25: ISAKMP (1033): incrementing error counter on sa, attempt 1 of 5: retransmit phase 1
Sep 12 23:46:26 8901: Sep 12 23:46:25: ISAKMP:(1033): retransmitting phase 1 AG_INIT_EXCH
Sep 12 23:46:26 8902: Sep 12 23:46:25: ISAKMP:(1033): sending packet to 91.62.130.220 my_port 500 peer_port 51041 (R) AG_INIT_EXCH
Sep 12 23:46:15 8865: Sep 12 23:46:15: ISAKMP:(0):atts are acceptable. Next payload is 3
Sep 12 23:46:15 8866: Sep 12 23:46:15: ISAKMP:(0):Acceptable atts:actual life: 86400
Sep 12 23:46:15 8867: Sep 12 23:46:15: ISAKMP:(0):Acceptable atts:life: 0
