Cisco Identity Services Engine (ISE) Version 1.2: Features and Troubleshooting
186
Participant
thru
With Ali Mohammed
Welcome to the Cisco Support Community Ask the Expert conversation. This is an opportunity to learn and ask questions about what’s new in Cisco Identity Services Engine (ISE) Version 1.2 and to understand the new features and enhanced troubleshooting options with Cisco expert Ali Mohammed.
Cisco ISE can be deployed as an appliance or virtual machine to enforce security policy on all devices that attempt to gain access to network infrastructure. ISE 1.2 provides feature enrichment in terms of mobile device management, BYOD enhancements, and so on. It also performs noise suppression in log collection so customers have greater ability to store and analyze logs for a longer period.
Ali Mohammed is an escalation engineer with the Security Access and Mobility Product Group (SAMPG), providing support to all Cisco NAC and Cisco ISE installed base. Ali works on complicated recreations of customer issues and helps customers in resolving configuration, deployment, setup, and integration issues involving Cisco NAC and Cisco ISE products. Ali works on enhancing tools available in ISE/NAC that are required to help troubleshoot the product setup in customer environments. Ali has six and a half years of experience at Cisco and is CCIE certified in security (number 24130).
Remember to use the rating system to let Ali know if you have received an adequate response.
Because of the volume expected during this event, Ali might not be able to answer each question. Remember that you can continue the conversation on the Security community, sub-community shortly after the event. This event lasts through September 6, 2013. Visit this forum often to view responses to your questions and the questions of other community members.
