mi204978
Beginner
Beginner
is there a way to monitor configuration changes in ACS 5.x. I would like to have a report or a message, when the configuration has changed (e.g. rules, policy elements, new hosts ....).
Thanks in advance.
Kind regards,
Michael
jrabinow
Rising star
Rising star
Go to Monitoring & Reports > Reports > Catalog > ACS Instance
select radio button by "ACS Configuration Audit" and then Run->Query and Run
can now enter your search requirements and press "Run" to generate the report
mi204978
Beginner
Beginner
Thank you that was exactly what I was looking for. Do you know if I can create a customized report and send scheduled it by email?
Recognize Your Peers
