TCC_2
Level 10
Level 10
Resolution
If the ParseAARealm and ParseAAARealm scripts do not appear on Cisco CNS Access Registrar version 3.0, perform these steps:
  1. Log in to aregcmd.
  2. Go to cd /radius/scripts.
  3. Add ParseAARealm.
  4. cd ParseAARealm.
  5. Set Language Rex. Set Filename librexscript.so. Set EntryPoint  ParseAARealm.
  6. Click Save.
  7. After adding the scripts, issue the reload command.
For information on CAR version 3.0 scripts, refer to Cisco Access Registrar Scripts.
click scripting for more information
