vnagarmu
Cisco Identity Services Engine v3.x offers major usability benefits across many of its use cases. With better speed and agility, you are able to achieve security resilience with a fully mature zero trust solution while gaining pervasive visibility and dynamic control.
I am Viraj Nagarmunoli, Solutions Architect with Customer Success and together with Security Customer Success Specialist @Yash Kejariwal, I put together the table below summarising some of the key features of ISE 3.x
Feel free to ask us any questions about Cisco ISE upgrades using the vnagarmu_0-1663924340405.pngbutton below the post.
Start planning your upgrade here.
If you want to stay up to date with our Software Compliance and key feature articles make sure to subscribe to the label 'Software Upgrades'
Capability Feature ISE 2.x ISE 3.x
Cloud Support
Cloud native ISE
Previously, ISE could only be deployed on a physical or a virtual appliance.
Now, you can deploy ISE on public cloud infrastructure including AWS, Azure and Oracle cloud as a native cloud solution. This can help you reduce operational expenses and gives you the ability to scale your deployment on-demand while automating routine tasks.
Policies for Azure AD
Previously ISE supported Azure AD identity provider using SAML and Oauth authentication protocols but there was limited support for dot1x
Now, Cisco ISE 3.x supports EAP-TLS and TEAP authentication with Azure AD.  This means that you can now create policies using group and attribute information when performing dot1x authentication which allows for differentiated and secure access.
Automation and APIs
Open API for system and policy management
Previously, API only exposed basic ISE infrastructure and session related content
With Open API support, ISE 3.x brings you a lot more automation capabilities such as policy and system management (like backups) while still supporting the other types of APIs
Zero Touch Provisioning
The traditional way of deploying ISE had several touch points and was a manual process. It took several hours setting up a large deployment
Now, the new Zero Touch Provisioning (ZTP) allows you to create a configuration file in which the ISE node can be configured (IP, hostname, DNS, etc.) Likewise, it can automatically install any hot fixes or patches immediately after it is set up.
Posture and Compliance
Posture on Linux
Previously, ISE Posturing could be performed on Windows and OS X machines.
ISE Posture can now be performed for Linux devices too, along with Windows and OS X. That way, all endpoints on the network can be kept compliant and, if found non-compliant, they can be quarantined and remediated.
Agentless Posture
Previously you had to have an application installed on the endpoint to perform posture checks
By popular request, ISE can now be configured to assess the posture of an endpoint without having to roll out client applications across your entire install base. For you this means you gain all the visibility necessary without the need of an additional application.
Promotion Alert: ISE 3.x offers a streamlined licensing scheme in line with Cisco DNA licensing tiers. Take advantage of the one year free licenses on Cisco limited-time promotion by upgrading your ISE deployment and licenses to version 3.x!
Ask the Experts Recording: Please watch this VoD as our experts walk you through the steps to prepare, perform, and validate a successful ISE upgrade without headaches. Best practices, strategies to minimise downtime and different methods of upgrades for different types of ISE deployments are covered.
Ask the Experts Live: If you would like to ask the questions to one of our ISE experts live in during webinar, please register to one of the Upgrade Planning and Best Practices: Upgrading ISE Ask the Experts sessions.
niroulabhaa
Beginner
Beginner
Is there any improvement or change in how we deploy NAC in the new ISE 3.x?
neysser
Beginner
Beginner
Thanks for the sharing info, it's very helpful for me as a ISE beginner user
vnagarmu
@niroulabhaa Network Access Control is the heart of many things that ISE does, and so, naturally, many things have evolved over the years and over the versions of ISE. The azure AD policy support discussed in this post is an example. Let me know if you're looking for something in specific for NAC and I'm happy to answer questions or discuss further.
JyrkiHalonen
Beginner
Beginner
Great and clear way of presenting updates and features, thanks for sharing.
thomashuette
Beginner
Beginner
thank you updating us with the new information
1967-mustang
Beginner
Beginner
We have been using ISE since the 1.x days.  Love the Azure AD integration and the Zero Touch node deployment.
EdsonVazquez
Beginner
Beginner
thank you for the information,
Thank you for the helpful information
rendy.rinaldy
Beginner
Beginner
is there a GCP support ISE Cloud plan?
vnagarmu
@rendy.rinaldy we are working on support for GCP so look forward to the announcement in one of the upcoming ISE 3.x versions
we have to try it, thanks for sharing
frch
Beginner
Beginner
Thanks for the infomation, nice update
jshupick
Rising star
Rising star
Thank you for sharing! Will have to wait and see when our Security guy implements this!
bezik
Beginner
Beginner
Thanks for information!
vnagarmu
Hey @Tommo80, the 'one year free licenses on Cisco' link is back online now! Thanks again for reporting.
