minkumar
Beginner
Beginner
    Introduction
    This document provides an example of TACACS+ authentication  configuration on a Nexus switch. By default, if you configure the Nexus  switch in order to authenticate through Access Control Server (ACS), you  are automatically placed in the network-operator/vdc-operator role,  which provides read-only access. In order to be placed in the  network-admin/vdc-admin role, you need to create a shell on the ACS 5.2.  This document describes that process.
    Requirements
    Ensure that you meet these requirements before you attempt this configuration:
    • Define your Nexus switch as a client in ACS.
    • Define the IP address and an identical shared secret key on the ACS and Nexus.
    Note: Create a checkpoint or a backup on Nexus before you make any changes.
    Components Used
    The information in this document is based on these software and hardware versions:
    • ACS 5.2
    • Nexus 5000, 5.2(1)N1(1)
    The information in this document was created from the devices in a  specific lab environment. All of the devices used in this document  started with a cleared (default) configuration. If your network is live,  make sure that you understand the potential impact of any command.
    Conventions
    Refer to the Cisco Technical Tips Conventions for more information on document conventions.
    Configuration
    In this section, you are presented with the information to configure the features described in this document.
    Note: Use the Command Lookup Tool (registered customers only) to obtain more information on the commands used in this section.
    Nexus Device for Authentication and Authorization with ACS 5.2 Configuration
    Complete these steps:
    1. Create a local user on the Nexus switch with full privileges for fallback:
      username admin privilege 15 password 0 cisco123!
    2. Enable TACACS+, then provide the IP address of the TACACS+ Server (ACS):
      feature tacacs+tacacs-server host IP-ADDRESS key KEY
      tacacs-server key KEY
      tacacs-server directed-request
      aaa group server tacacs+ ACS
      server IP-ADDRESS
      use-vrf management
      source-interface mgmt0
      Note: The key must match the shared secret configured on the ACS for this Nexus device.
    3. Test the TACACS server availability:
      test aaa group group-name username password
      The test authentication should fail with a reject message from the  server, since the server has not been configured. This reject message  confirms that the TACACS+ server is reachable.
    4. Configure login authentications:
      aaa authentication login default group ACSaaa authentication login console group ACS
      aaa accounting default group ACS
      aaa authentication login error-enable
      aaa authorization commands default local
      aaa authorization config-commands default local
    Note: Nexus uses local authentication if the authentication server is unreachable.
    ACS 5.x Configuration
    1. Navigate to Policy Elements > Authentication and Permissions > Device Administration > Shell Profiles in order to create a Shell Profile.
    2. Enter a name for the profile.
    3. Under the Custom Attributes tab, enter these values:
    Attribute: cisco-av-pair
    Requirement: Mandatory
    Value: shell:roles*"network-admin vdc-admin"
    4. Submit the changes in order to create an attribute-based role for the Nexus switch.
    5. Create a new authorization rule, or edit an existing rule, in the  correct access policy. By default, TACACS+ requests are processed by the  Default
    6. Device Admin access policy.
    In the Conditions area, choose the appropriate conditions. In the Results area, choose the Nexus OS shell profile.
    7. Click Ok.
    Verify
    Use this section to confirm that your configuration works properly.
    The Output Interpreter Tool (registered customers only) (OIT) supports certain show commands. Use the OIT to view an analysis of show command output.
    Reference
    Please post comments if there are any queries and rate if useful
    Majed Zouhairy
    Beginner
    Beginner
    in acs 5.2, I add the stated:
     it adds, but when I click submit, the acs just logs out. Anything to do?
    Recognize Your Peers
