Asa 5510 and telnet
We have a problem with doing telnet to inside and outside interface. When we try to do, We received this message. Wha have permit any any in both interface but we can´t doing telnet.
Somebody know what we have doing  to solve it??
Version Asa is 8.2.5 model 5510
thanks.
%ASA-4-402117: IPSEC: Received a non-IPsec (protocol) packet from
remote_IP to local_IP.
Hi Bro
You cannot telnet to an outside interface that has security-level 0. You can only ssh, to an outside interface with security-level 0. In general, if any interface that has a security level of 0 or lower than any other interface, then the PIX/ASA does not allow telnet to that interface.
However, if you’re still adamant that you’d like to telnet to the outside interface, then this can be achieved but the steps are too many, too much of an hassle. Well, in order to enable a Telnet session to the outside interface, configure IPsec on the outside interface to include IP traffic that is generated by the Cisco FW and enable Telnet on the outside interface.
It is not recommended to access the security appliance through a Telnet session. The authentication credential information, such as password, are sent as clear text. The Telnet server and client communication happens only with the clear text. Cisco recommends using SSH for a more secured data communication.
For further details on this, please do refer to this URL http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a008069bf1b.shtml
domain-name cisco.com
ssh version 2
crypto key generate rsa modulus 768
ssh 202.188.5.0 255.255.255.0 outside
telnet 192.168.10.13 255.255.255.255 inside
P/S: If you do find this comment useful, please do rate them nicely :-)
Warm regards,
Ramraj Sivagnanam Sivajanam
12 Replies 12
hi,
add these line:
telnet inside
telnet outside
regards
V
please attach your config
thanks for your soon answer.
But, we have the same issue.
We wrote the command  telnet 192.168.0.0 255.255.0.0 outside
Attached please find a picture.
if you need more config please let us know.
Thanks.
i see in the picture other subnet in telnet access: 10.161.0.0/16 not 192.168.0.0 255.255.0.0
Sorry , it is a mistake, the correct is
telnet 10.161.0.0 255.255.0.0 outside
what is the ip address of RDP-FJD ?
second:
do you have user o group enable to telnet?
exaple:
aaa authentication telnet LOCAL
RDP-FJD is 10.161.1.71
We haven´t group. We try to enter the sentence that you tell us but no run...
thanks
well,
you cannot configure telnet in outside interface or lowest interface, use ssh
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a008069bf1b.shtml#telnet
Note: You can enable Telnet to the security appliance on all interfaces. However, the security appliance enforces that all Telnet traffic to the outside interface be protected by IPsec. In order to enable a Telnet session to the outside interface, configure IPsec on the outside interface to include IP traffic that is generated by the security appliance and enable Telnet on the outside interface.
Note: In general, if any interface that has a security level of 0 or lower than any other interface, then PIX/ASA does not allow Telnet to that interface.
We try to doing like you tell us.
Thanks!!!.
Regards.
Hi Bro
ssh version 2
Warm regards,
I tested this confuguración and it works.
interface Ethernet0/1.82
vlan 82
nameif transito-asa-cpe
security-level 50
ip address 192.168.0.1 255.255.255.252
ssh version 2
ssh Lan-FJD 255.255.0.0 outside
telnet 192.168.0.0 255.255.255.252 transito-asa-cpe
Thank you very much for your help.
Cheers.
