07-01-2015 01:09 AM - edited 02-21-2020 05:31 AM
Want to know Cisco bug CSCur60060 is corrected in ASA version 9.4 or not? Can someone please help in this. Thanks!!
07-13-2015 10:47 PM
It does not listed under the resolved bugs so my guess is that it was not fixed in that release:
http://www.cisco.com/c/en/us/td/docs/security/asa/asa94/release/notes/asarn94.html
Thank you for rating helpful posts!
04-30-2016 10:42 PM
I'm running 9.5.2 on this ASA and it is still showing that error.
09-16-2015 03:01 PM
Running 9.4.1 and I can confirm it has not been corrected.
10-02-2015 09:50 AM
I can confirm the bug exists on 5585x running 9.4(1)3.
01-28-2016 03:44 PM
I am running ASA version 9.5(1) and bug still exist however, bug is cosmetic and command still goes through.
Here is Cisco's response which is my observed result as well:
Symptom:
ASA prints following error incorrectly even when the route is correct:
WARNING: configured logging host interface conflicts with route table entry
Conditions:
This is seen on configuring a new syslog server or removing an existing one.
Workaround:
This is cosmetic. Command still takes effect.
05-10-2016 08:45 AM
I am running ASA with software 9.5(2) and see that warning too using CLI to configure. Using ASDM no warnings are displayed.
07-04-2016 09:42 AM
Cisco Adaptive Security Appliance Software Version 9.4(2)11
The same issue.
08-05-2019 10:02 AM
Running ASA 9.8(2)20 and still have this issue
