205
Highlighted
Beginner
ASA Object Replacement
Hi!
I would like to replace objects with an updated name for example:
object a ===== object ab
They function the same, only with a different name.
Is there a way I can replace these without having to clear the objects and recopying them?
Thanks!
Everyone's tags (1)
1 REPLY 1
VIP Advisor
In ASDM just edit the object
In ASDM just edit the object and put in a new name.  It will rename it for you.
