02-13-2009 12:41 AM - edited 02-21-2020 03:17 AM
I'm monitoring our Cisco ASA via SNMP.
So far I found :
- Total number of RAS sessions : 1.3.6.1.4.1.9.9.392.1.3.1.0
- Number of IPSec VPN tunnels : 1.3.6.1.4.1.9.9.171.1.3.1.1.0
- Total number of SSL Sessions : 1.3.6.1.4.1.3076.2.1.2.26.1.2.0
I'm looking for these OID's :
- Number of SSL Sessions via the Anyconnect VPN client (SSL VPN)
- Number of Clientless SSL sessions
Thanks in advance
02-13-2009 09:09 AM
see if these one works for you:
SSL Stats are in ALTIGA-SSL-STATS-MIB. You are looking for alSslStatsActiveSessions.
snmpwalk -c
http://tools.cisco.com/Support/SNMP/do/BrowseMIB.do?local=en&mibName=ALTIGA-GLOBAL-REG#
05-24-2017 02:50 AM
Hi community,
Knowing that this post is 8 years old, is it still possible to get a response on it or should i open a new thread?
I am wondering if anyone managed to come up with a solution to monitor seperately active and inactive sessions on an asa 5525. there only seems to be one oid for combining the sessions. Currently we are looking at the total sessions for atm anyconnect but want to see it split.
Dino
02-25-2009 06:26 AM
Anyone ?
Help would be very much appreciated
02-25-2009 06:58 AM
Did you check my last post? was it not useful?
02-25-2009 07:18 AM
Hi, thanks for the reply but I already found the MIB containing the "Total number of SSL Sessions" : 1.3.6.1.4.1.3076.2.1.2.26.1.2.0 ".
I'm looking for separate SSL connection OID's :
04-18-2012 03:34 AM
I have found some resources here, might be helpful for you:
crasSVCNumSessions 1.3.6.1.4.1.9.9.392.1.3.35.0
crasWebvpnNumSessions 1.3.6.1.4.1.9.9.392.1.3.38.0
03-17-2020 09:20 AM
Below are some useful OIDs
to get IP of connected active users 1.3.6.1.4.1.9.9.392.1.3.21.1.8
Number of maximum users can be connected 1.3.6.1.4.1.9.9.467.1.1.5
Number of IPsec client connected .1.3.6.1.4.1.9.9.392.1.3.26
Number of current anyconnect client connected .1.3.6.1.4.1.3076.2.1.2.26.1.2.0
03-18-2020 03:22 AM
Would love to know the OIDs that relate to each of these values, particularly each type of AnyConnect user.
VPN Session Summary
Active : Cumulative : Peak Concur : Inactive
AnyConnect Client : 43 : 17172 : 96 : 1
SSL/TLS/DTLS : 6 : 3295 : 21 : 0
IKEv2 IPsec : 37 : 13877 : 82 : 1
Clientless VPN : 1 : 17837 : 47
Browser : 1 : 17837 : 47
IKEv1 IPsec/L2TP IPsec : 23 : 3336 : 29
Site-to-Site VPN : 20 : 1200779 : 28
IKEv2 IPsec : 4 : 2013 : 7
IKEv1 IPsec : 16 : 1198766 : 24
Total Active and Inactive : 88 Total Cumulative : 1239124
Device Total VPN Capacity : 750
Device Load : 12%
11-07-2023 11:47 PM
I have the same problem, did you manage to get the OID? please share.
Thank you!
03-24-2024 08:23 AM
Check out VPNTTG (VPN Tunnel Traffic Grapher) is a software for SNMP monitoring and measuring the traffic load for IPsec (Site-to-Site, Remote Access) and SSL (With Client, Clientless) VPN tunnels on a Cisco ASA. It allows the user to see traffic load on a VPN tunnel over time in graphical form.
Advantage of VPNTTG over other SNMP based monitoring software's is following: Other (commonly used) software's are working with static OID numbers, i.e. whenever tunnel disconnects and reconnects, it gets assigned a new OID number. This means that the historical data, gathered on the connection, is lost each time. However, VPNTTG works with VPN peer's IP address and it stores for each VPN tunnel historical monitoring data into the Database.
For more information about VPNTTG please visit www.vpnttg.com
