11-14-2011 10:10 PM - edited 02-21-2020 04:30 AM
I have problem launching ASDM Launcher with ASA 5510, When ever i try to run the ASDM it says software update completed and it goes off after which nothing comes in the screen.
Can someone please help me with this configurations..
11-15-2011 11:07 AM
What versions of ASA IOS and ASDM image are you running? Ensure that ASDM version that you are using is compatible with your ASA IOS image. Let me know the versions as requested and i'll let u know if they are compatible or not. Else please do refer the release notes for the code you are using.
Was it working fine before? If yes, then have you downloaded and installed java update lately?
Please refer the ASDM release notes and ensure you have the correct version of the Java installed on the PC machine from where you are trying to access ASA's GUI.
11-15-2011 07:30 PM
Thank you for the reply .. the following are the version of ASA IOS and ASDM
sh flash:
-#- --length-- -----date/time------ path
6 5548032 Jan 01 2003 00:07:04 asa708-k8.bin
7 0 Oct 07 2008 13:17:36 crypto_archive
8 6163744 Oct 07 2008 13:31:30 asdm-508.bin
This was the first time trying to connect to ASA with ASDM
I have even tried to launch the Asdm on the browser still it doesnot pop up ...
11-15-2011 11:22 PM
you mean when you browse the ASA, it does not pop up for the username/password .. i thought you having issue afterwards...
have you tried opening it from different browser/machine.. just checking on java thing...
http://www.cisco.com/en/US/docs/security/asa/asa70/asdm50/release/notes/rn508.html#wp139067
Both images are good to go together. Please do share
sh run http
sh run boot
sh ver
11-16-2011 12:23 AM
Thank you for the reply..
asabob# sh run http
http server enable
http 192.168.115.0 255.255.255.0 inside
asabob# sh boot
asabob# sh version
Cisco Adaptive Security Appliance Software Version 7.0(8)
Device Manager Version 5.0(8)
Compiled on Sat 31-May-08 23:48 by builders
System image file is "disk0:/asa708-k8.bin"
Config file at boot was "startup-config"
asabob up 57 days 2 hours
failover cluster up 57 days 2 hours
Hardware: ASA5510, 256 MB RAM, CPU Pentium 4 Celeron 1600 MHz
Internal ATA Compact Flash, 256MB
BIOS Flash M50FW080 @ 0xffe00000, 1024KB
Encryption hardware device : Cisco ASA-55x0 on-board accelerator (revision 0x0)
Boot microcode : CNlite-MC-Boot-Cisco-1.2
SSL/IKE microcode: CNlite-MC-IPSEC-Admin-3.03
IPSec microcode : CNlite-MC-IPSECm-MAIN-2.05
0: Ext: Ethernet0/0 : address is 0022.90c1.e3b8, irq 9
1: Ext: Ethernet0/1 : address is 0022.90c1.e3b9, irq 9
2: Ext: Ethernet0/2 : address is 0022.90c1.e3ba, irq 9
3: Ext: Ethernet0/3 : address is 0022.90c1.e3bb, irq 9
4: Ext: Management0/0 : address is 0022.90c1.e3b7, irq 11
5: Int: Internal-Data0/0 : address is 0000.0001.0002, irq 11
6: Int: Internal-Control0/0 : address is 0000.0001.0001, irq 5
Licensed features for this platform:
Maximum Physical Interfaces : Unlimited
Maximum VLANs : 25
Inside Hosts : Unlimited
Failover : Active/Standby
VPN-DES : Enabled
VPN-3DES-AES : Enabled
Security Contexts : 0
GTP/GPRS : Disabled
VPN Peers : 150
This platform has an ASA 5510 Security Plus license.
Serial Number: JMX1241L0LH
Running Activation Key: 0xf329d940 0xd4b2bcd2 0xf44029a8 0x95407ce0 0x482230b7
Configuration register is 0x1
Configuration last modified by enable_15 at 00:11:41.624 UTC Wed Feb 26 2003
I have Attached a screen shot: After the " Please wait.... main window is coming up.." is shown the configuration window never pops up i have tried with different browser and machine also ... (eg Netscape 7.2 and also in windows XP)
11-16-2011 12:27 AM
after this nothign pops up and when i run it through ASDM Launcher it says "software update completed" after that nothign comes up ..
12-25-2011 08:34 AM
Is your client on network 192.168.115.0 255.255.255.0?
Given your relatively old image, I don't suppose you have Smartnet on this device. If you did, I'd suggest moving to a more recent release of ASA and ASDM software. ASA 8.2(5) with ASDM 6.4.5 is a very stable and relatively recent release. Plus one can download the MSI installer for Windows directly from Cisco for newer ASDM releases and not be dependent on pulling it down from the ASA.
