ASDM will not open
I recently installed ASDM to configure a new ASA5525, when I launch the tool i get an error saying it can't connect. Looking at the Java logs I see this entry every time I try to connect:
javax.net.ssl.SSLHandshakeException: Received fatal alert: handshake_failure
I've changed Java version to match a co-worker who can launch the tool with no issues.
What else do I need to change to get this working?
1 ACCEPTED SOLUTION
Highlighted
Re: ASDM will not open
 fix is to uncheck the "Use SSL 2.0 compatible ClientHello format" in Advanced tab of the Java Control Panel (At the bottom).
This worked for me.....
1 REPLY 1
Highlighted
