03-26-2013 09:11 PM - edited 02-21-2020 04:51 AM
My Scenario:
Cisco ASA 5510 directly facing the internet on E0/0 (1 Public IP only) with internal LAN on E0/1. Exchange 2010 OWA working fine with ACL and NAT rules configured.
Problem:
Help please .
03-27-2013 01:57 PM
You may get more responses to this if you pose it in the firewalling discussion group.
What version of the ASA software are you running? There is a NAT syntax and function discontinuity at 8.3.
For (1) and (2), you can publish multiple servers from inside private addresses to a single public outside address using static PAT provided the outside mapped ports are all different.
For (3), I'm guessing the the parent certificate which signed your ASA cert isn't configured as a trustpoint.
Would it be possible for you to post your configuration, or excerpts from it?
-- Jim Leinweber, WI State Lab of Hygiene
03-27-2013 02:30 PM
Thanks for the reply, I'm running v8.2(5).
Please find below my asa config:
: Saved
ASA Version 8.2(5)
hostname xxxciSCOASAXX
enable password encrypted
passwd encrypted
names
name 10.70.75.XX XXXsrvmx01 description Exchange-Server
name 202.62.XXX.XXX mail.caaf.org.fj description ExtInt
name 10.70.75.XX XXcenter description vmware
name 10.70.75.XX DVR description dvr
name 10.70.75.XX ICTA description ICT Laptop
name 10.70.75.XX XXXsrvaqd01 description AQDportal
name 10.70.75.XX XXSS-Int description hrss
name 10.70.75.XX otrs description otrs
dns-guard
interface Ethernet0/0
description WAN_Link
nameif outside
security-level 0
ip address XXX.XXX.org.fj 255.255.255.252
interface Ethernet0/1
description LAN_Link
nameif inside
security-level 100
ip address 10.70.75.XX 255.255.255.0
interface Ethernet0/2
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
nameif management
security-level 100
management-only
ftp mode passive
clock timezone FJST 12
object-group service DM_INLINE_TCP_1 tcp
port-object eq ftp
port-object eq www
port-object eq https
port-object eq pop3
port-object eq smtp
object-group service DM_INLINE_TCP_2 tcp
port-object eq smtp
object-group protocol TCPUDP
protocol-object udp
protocol-object tcp
access-list global_mpc extended permit tcp any any object-group DM_INLINE_TCP_1
access-list outside_access_in_1 extended permit tcp any interface outside object-group DM_INLINE_TCP_2
access-list outside_access_in_1 extended permit tcp any interface outside eq 100
pager lines 24
logging enable
logging asdm informational
mtu outside 1500
mtu inside 1500
mtu management 1500
icmp unreachable rate-limit 1 burst-size 1
icmp permit any inside
asdm image disk0:/asdm-645.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
static (inside,outside) tcp interface smtp XXXsrvmx01 smtp netmask 255.255.255.255
static (inside,outside) tcp interface https XXXsrvmx01 https netmask 255.255.255.255
static (inside,outside) tcp interface 100 DVR 100 netmask 255.255.255.255
access-group outside_access_in_1 in interface outside
route outside 0.0.0.0 0.0.0.0 202.62.xxx.xxx 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 192.168.1.0 255.255.255.0 management
http 0.0.0.0 0.0.0.0 inside
http authentication-certificate inside
http authentication-certificate management
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto ca trustpoint _SmartCallHome_ServerCA
crl configure
crypto ca trustpoint ASDM_TrustPoint0
enrollment self
subject-name CN=xxxCISCOASAxx
crl configure
crypto ca server
shutdown
smtp from-address admin@xxxCISCOASAxx.null
quit
telnet 0.0.0.0 0.0.0.0 inside
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 192.168.1.2-192.168.1.254 management
dhcpd enable management
threat-detection basic-threat
threat-detection scanning-threat
threat-detection statistics host
threat-detection statistics access-list
threat-detection statistics tcp-intercept rate-interval 30 burst-rate 400 average-rate 200
ssl trust-point ASDM_TrustPoint0 outside
webvpn
svc enable
group-policy DfltGrpPolicy attributes
vpn-tunnel-protocol IPSec l2tp-ipsec
group-policy remoteVPN internal
group-policy remoteVPN attributes
vpn-tunnel-protocol webvpn
tunnel-group RemoteVPN type remote-access
tunnel-group RemoteVPN general-attributes
address-pool VPN_pool
default-group-policy remoteVPN
class-map global-class
match access-list global_mpc
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum client auto
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect ip-options
inspect icmp
inspect icmp error
class global-class
csc fail-close
service-policy global_policy global
prompt hostname context
call-home reporting anonymous
Cryptochecksum:fd21551
: end
