Highlighted
CISCO Network assistant work with core SEED is a NEXUS 57U2UP
Hello
We are trying to deterrmine if the NEXUS 57U2 with CIsco CATALYST downstream switches would be able to be worked with for the CISCO network Assistant? as the NExus is at the core, this is what is needed to make most of the connections so without this being able to be leverages the tool would be off less use.
Please advise if this  would work with the free CISCO NETWORK assistant, or if it can be mitigated or such, or if there is a different low cost / free option we can use for managing of the Cisco equipment at our locale where there is the NEXUS at the core and CISCO CATALYST 29xx equipment after it?
Thank you
thank you
Everyone's tags (2)
