Cisco Community Designated VIP Class of 2020
582
Highlighted
Beginner
Limited show Running right.
I have to share show running rights with a clinet. i want to restrict out put in a way. it should not show my SNMP IP, and WAN interface IPs. can i do this ?
thanks
Everyone's tags (2)
1 REPLY 1
Hall of Fame Guru
I believe if you set the privilege level of the snmp-server and related commands higher than the user's privilege level that should do the job. I just tried this and found it a bit tricky in practice. You might be able to get that to work with enoughtweaking.
I also tried (successfully) using the autocommand feature. Have the autocommand execute thus:
     username six autocommand show run | ex host | address
However that does exclude all "ip address" lines, not just WAN ones. It will prevent the user from doing anything else though - they are logged out as soon as "show run" reached the end of the config.
Content for Community-Ad
FusionCharts will render here
