10-31-2008 08:28 AM - edited 02-21-2020 03:04 AM
Hi all,
I have some problems with some applications as Xcics and Citrix when client and server are connected through a vpn site-to-site. Clients don't seem to have any problem to connect to the server, but after a period of time, they disconnect even if users are working. Session is not closed correctly on server and stay hung, so users can't connect if the administrator doesn't close the session on the server. Some vpns pass through a Pix515E, others pass through a fwsm and an ASA5510. Does anyone knows something about this issue?
11-04-2008 03:11 AM
Have you enabled isakmp keepalives?
Farrukh
11-06-2008 06:59 AM
Yes, and I have a software to monitor the connections which sends a ping every 1 minute. Disconnections happen when users are working, not after a period of inactivity.
11-07-2008 06:12 AM
Try increasing theses values..
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00
11-14-2008 06:06 AM
I have controlled with ASDM.Values you indicate are unchecked on my firewall. ASDM guide says "unchecking the check
boxes means there is no timeout value", so the problem is not caused by timeouts, is it?
04-29-2010 12:09 AM
I resolved the problem configuring connection timeout = 2 hours.
07-21-2010 12:19 AM
problem solved, see my post of 29-apr-2009
