QOS giving outbound priority to a port, is it possible with C850/IOS 12.3?
bbiales00
I've got a realtime application that uses a particular port, say, 9000 for inbound and outbound UDP traffic. Since I have off-site users that can use up all my outbound bandwidth at times, when they do this, the realtime app suffers. I would love to give this port priority, so these packets go out first no matter what else is going on (I know I cannot control the order the packets arrive...). Unfortunately, I have little IOS experience. I can tweak Access lists and NAT settings, but I don't see how to do this QOS feature with my router. Is it even possible? I've been told it will support QOS, but I'm not so sure... If my current config would help, let me know and I will post it.
Thanks for any insights/direction you can provide.
22 Replies 22
Well, to make this easier, I've attached a scrubbed version of my config. This is, in fact, also my ADSL router, the interface is called Dialer1. There is also a site-to-site VPN in the config, but I think we can ignore that for now. I've removed all the NAT's from the config (which are required to go through the site-to-site VPN...).
I believe our service is 6Mbs in to the router, and 768Kbs out to the internet.
Let me know what's next. Thanks.
OK - I would try something like:-
class-map match-all pri-app
match access-group 101
policy-map mark-app
class pri-app
set precedence 5
class class-default
set precedence 0
policy-map App-QoS
class pri-app
priority xx - the number in kilo bits per second you want to assign the app in LLQ
class class-default
fair-queue
random-detect dscp-based
interface Dialer1
service-policy output App-QoS
There is an addition to the marking policy - to mark all other traffic = class default.
Ok, I'm almost there...
I now have:
policy-map App-QoS
class pri-app
priority 200
class class-default
fair-queue
policy-map mark-app
class pri-app
set precedence 5
class class-default
set precedence 0
I had to leave off the "random-detect dscp-based" because these are not available on my 877:
Here are the available commands:
r12(config)#policy-map App-QoS
r12(config-pmap)#class class-default
r12(config-pmap-c)#?
QoS policy-map class configuration commands:
bandwidth Bandwidth
compression Activate Compression
drop Drop all packets
exit Exit from QoS class action configuration mode
fair-queue Enable Flow-based Fair Queuing in this Class
netflow-sampler NetFlow action
no Negate or set default values of a command
police Police
priority Strict Scheduling Priority for this Class
queue-limit Queue Max Threshold for Tail Drop
service-policy Configure Flow Next
set Set QoS values
shape Traffic Shaping
And finally, I got an error setting this policy for the Dialer1 interface:
r12(config)#interface dialer1
r12(config-if)#service-policy output App-QoS
Must remove fair-queue configuration first.
Class Based Weighted Fair Queueing will be applied only to the Virtual-Access interfaces associated with an MLP bundle.
r12(config-if)#
I don't fully comprehend the error message. Should I just remove the fair-queue line? So default class packets will simply be FIFO?
Thanks again!
OK - this is an interesting error, so in the dialer interface configure no fair-queue
Then apply the service policy again - is there is another error, I am thinking that the QoS policy could only be applied to a ATM PVC/DSL interface - not 100% sure....will reearch this.
Well, I configured no fair-queue and then applied the QoS policy, but not all at once, and here is what it said at that time:
r12(config)#int dialer1
I/f Virtual-Access1 class pri-app requested bandwidth 200 (kbps), available only 42 (kbps)
r12(config-if)#
I did a DSL Reports bandwidth test and it reported 4000+ receive speed and 600+ upload speed, so I don't understand why it thinks there is only 42kbs to reserve...
This QoS stuff is anything but simple, that is for sure!
So now, I see things are not setup properly, I don't think I ever "saved" that config. So I went back to config mode, entered the following, and my router dropped all its connections, and my telnet session was cancelled...
Here is what I tried:
r12(config-if)#no fair-queue
Anyway, when I reconnect, and look at the config, the dialer1 interface has no fair-queue but no policy-map either. So I typed "write mem" and looked again, and the fair-queue is back, here is what Dialer1 looks like...
Still no service policy defined :-(
interface Dialer1
ip address negotiated
ip nat outside
ip virtual-reassembly
encapsulation ppp
dialer pool 1
fair-queue 64 16 256
no cdp enable
ppp authentication pap callin
ppp pap sent-username MyUserName password 0 MyPW
crypto map r12vpn
Apply the service policy map to the "interface ATM0.1 point-to-point"
Odd. I could not add to interface atm0.1 I did not write down the error, but it said it could not be put on a subinterface. So I put it on the ATM interface, but while it is there, some counts at the bottom of this report make me think nothing is matching...
Well, here are a couple reports, maybe it is working... What do you think?
r12#sh policy-map int atm0
ATM0
Service-policy output: App-QoS
Class-map: pri-app (match-all)
22365 packets, 6707964 bytes
5 minute offered rate 22000 bps, drop rate 0 bps
Match: access-group 101
Queueing
Strict Priority
Output Queue: Conversation 264
Bandwidth 200 (kbps) Burst 5000 (Bytes)
(pkts matched/bytes matched) 0/0
(total drops/bytes drops) 0/0
Class-map: class-default (match-any)
251771 packets, 62042165 bytes
5 minute offered rate 170000 bps, drop rate 0 bps
Match: any
Queueing
Flow Based Fair Queueing
Maximum Number of Hashed Queues 256
(total queued/total drops/no-buffer drops) 3/0/0
ATM0
22712 packets, 6840907 bytes
5 minute offered rate 26000 bps, drop rate 0 bps
Queueing
Strict Priority
251873 packets, 62084585 bytes
5 minute offered rate 162000 bps, drop rate 0 bps
Match: any
Queueing
r12#
